28th Sep 2019, 5:00 pm | #1 |
Yaesu FT101Z motorboating sound
When I switch on my Yaesu FT101Z, on main bands ie 20m, 40m or 80m etc. on receive I get a sound like motorboating which seems to be tunable, any ideas what the problem could be?
Thanks |
29th Sep 2019, 5:05 am | #2 |
Re: Yaesu FT101Z motorboating sound
if it was me the first thing i would check is all the psu voltages against the schematic,then caps for high esr.
29th Sep 2019, 12:28 pm | #3 |
Fist thing to do is plug in a dummy load then see if the noise is still present.
29th Sep 2019, 8:07 pm | #4 |
Hi, Checked out with Dummy load connected, Same symptoms. Thanks Richard. I'll now start checking out the voltages and capacitors it sounds like an electrolytic has gone o/c. need to source voltage values and some capacitors. Thank you M3VUV51
29th Sep 2019, 8:45 pm | #5 |
The old 101Z is prone to dodgy switches due to aging. I would give all of them a good working over before anything else especially the push button switch bank under the vfo
