14th Nov 2013, 10:36 pm | #1 |
Portadyne Record Player ID required.
I have just got a Portadyne record player (as shown) and am unable to identify the year and model of this player. It has a BSR deck. I have done a search but cannot find this model anywhere including the web.
Any input to my mystery much appreciated Last edited by Station X; 15th Nov 2013 at 8:13 am. Reason: New thread started. Readability |
15th Nov 2013, 7:19 pm | #2 |
Re: Portadyne Record Player ID required.
The BSR deck is a model UA8 which would be from the late 1950s. Have you looked to see what valve types are used in the player?
15th Nov 2013, 7:54 pm | #3 |
Hi Andy and welcome,
Very attractive machine and in good condition too. As Fidelity Fan says, we need to know what valves it uses to help you further. Nick. |
15th Nov 2013, 9:10 pm | #4 |
You could see if there's any date on the smoothing can- the set can't be earlier than that!
22nd Nov 2013, 10:01 pm | #5 |
Thank you everyone.
I will check all the above and report back. Thanks for the welcome too from Nickthedentist. |
23rd Jan 2016, 2:34 pm | #6 |
I have just acquired the same model from a garage clear out. It seems cosmetically nice and mechanically perfect as far as loading and playing and returning, which is a surprise. No sound though, I would assume down to that little brown TC8M cartridge I've had dealings with before. The modern stereo replacement cartridges sold on ebay didn't sound very good in my opinion. I'll look out for a working original, if I'm lucky enough to find one.
23rd Jan 2016, 6:14 pm | #7 |
Modern stereo cartridges should sound fine in this, but they may not play as loud as the BSR TC8M. The record player was made in 1957 or early 1958. It should have a 6.5" round speaker. The amplifier will have at least 2 stages and based on con-current Portadynes, may use an ECL82 with a 6X4/EZ90 rectifier. The best cartridge to fit to this is a Mono BSR X5M stereo-compatible, still available (I hope) from Musonic. Edward
