Old 12th Oct 2018, 1:30 pm   #41
Welsh Anorak
Welsh Anorak's Avatar
Default Re: A pair of Rediffusion monos....
The last 1500s were nice sets, with varicap tuning, slider controls and all the modifications present. And nice tried and tested circuitry, a LOPT that never failed, and a far better picture than the 1615 with its imported tube. I never recall anyone worrying about the slightly longer warm-up time.
Glyn
www.gdelectronics.wales
Welsh Anorak is offline
Old 15th Oct 2018, 9:09 pm   #42
Colourstar
Colourstar's Avatar
Having parked up the Mk13 chassis set whilst a UHF tuner module is sourced, I've had a look a the MK10.
Initial tests revealed a short circuit boost cap - one of the blue and white moulded plastic types. I have no service info on the MK10 and unfortunately the value is partially obliterated- It's either 0.047uf or 0.47uf at 1000v. Does anyone have this information?
Ta!
Colourstar is offline
Old 15th Oct 2018, 9:50 pm   #43
jayceebee
jayceebee's Avatar
Do you have a picture of it? 0.47uF at 1000v will be a rather large physical size .
John.
jayceebee is offline
Old 15th Oct 2018, 10:44 pm   #44
Colourstar
Colourstar's Avatar
Good point John- a 0.47uf of that vintage would be quite a size. I think it must be a 0.047uf. For some reason it's encased in a clear sleeve, which I've peeled back. I think the mangled figure was done during the manufacturing process.
Steve
Old 15th Oct 2018, 11:24 pm   #45
neil29
neil29's Avatar
Hi Steve, I remembered when you and rob had gone home that I have the proper service manual for this chassis which you're welcome to if you want it.
Neil.
neil29 is offline
Old 15th Oct 2018, 11:39 pm   #46
neil29
neil29's Avatar
Hi Steve, C507 is a 0.047 1000v according to the manual.
Neil.
neil29 is offline
Old 16th Oct 2018, 8:33 am   #47
MALC SCOTT
MALC SCOTT's Avatar
Hi, when i first started working for Rediffusion w/shop Newton Aycliffe in 1975 i was on grade F, which was mono only. I spent hundreds of hours on the Mk 10 test rig. The stab boards had to have had stand off valve bases fitted, a 10k safety resistor was fitted in series with the VDR and the 330k boost feed resistor was changed to a 220k. The 0.01 boost decoupling cap was replaced with a disc type. Early chassis needed the tag strip replacing due to heat damage and one of the w/w resistors was removed from it an mounted on the top of the chassis on a seperate tag strip. The s/f t/b panel was reliable, Bfy52 and 15v zener diode caused hum bars, early boards used a BLY 48 frame o/p instead of the more reliable 2N3055. The Mk10 chassis ran for years, Malc.
Malc Scott
MALC SCOTT is offline
Old 16th Oct 2018, 7:24 pm   #48
Colourstar
Colourstar's Avatar
Hi Neil
Thanks for confirming the cap is a 0.047uf and for the offer of a manual. I'll take you up on that!
Hi Malc
You may be able to solve one mystery on this chassis- the presets for the two line holds and the vertical hold and mounted vertically behind a metal 'barrier' which seems to be there specifically to stop them being adjusted! Theres no room to insert even the smallest screwdriver. On any other set of the era these are user adjustable but on this set they don't even appear to want an engineer to get at them. Any reason? The linearity and height are mounted horizontally next to them and can be adjusted with ease.
__________________________________________________ ________
Meanwhile, replacement of the s/c boost cap and the o/c 1 meg resistor in series with it has brought forth EHT (hooray!) and a fairly dim raster, which could be down to the fact it seems suspiciously wide and tall, although the line structure at 405 is visible. There's also a distinct whiff of ozone from the LOPT. Hmm.
Steve
Name:	MlK10 presets.jpg
ID:	171080   Click image for larger version
Name:	Mk10 first light.jpg
ID:	171081   Click image for larger version
Old 16th Oct 2018, 8:40 pm   #49
Colourstar
Colourstar's Avatar
I connected up the Rediffusion translator box and into that fed a VCR running a 405 line VHS tape, so at least I had a picture to look at.
Unfortunately the EHT drops off fairly rapidly a few minutes after switch on, dropping down to the point where the picture disappears. The overwind on the LOPT gets pretty warm too.
Not looking good unfotunately!
ID:	171088   Click image for larger version
ID:	171089   Click image for larger version
ID:	171090   Click image for larger version
ID:	171091   Click image for larger version
Old 16th Oct 2018, 9:10 pm   #50
jayceebee
jayceebee's Avatar
Oh dear that's a shame, the lopt has an RBM A774 look about it so maybe not a complete surprise. The overwind looks to be a potted type so passing current through to drive out any moisture won't help I suspect.
Is it plug in by BTW. There looks to be an edge connector on the main winding?
John.
Old 16th Oct 2018, 9:42 pm   #51
Colourstar
Colourstar's Avatar
Hi John
Yes it's rather disappointing although not too surprising I suppose. If left on, the overwind gets really quite hot.
The LOPT can be removed very easily;pop off the EHT connector from the crt, remove the edge connector, move a metal spring clip and it lifts straight out. The entire set is very pluggable (or unpluggable).
The last MK10 I had suffered from a duff LOPT. It went to Malc, so I wonder if he had any luck with it...
Steve
Old 17th Oct 2018, 12:09 am   #52
MALC SCOTT
MALC SCOTT's Avatar
Hi Steve, the vertical mounted pre-sets can be adjusted with your finger. The faulty loptx we had at Rediffusion were all sent to our Rochdale factory and were returned triplerised. The faulty overwinds removed and a tripler fitted. They worked ok, but the eht regulation was never as good as a valve eht rec.
Try drying the loptx out for a week of so in a dry, warm place, Malc.
Malc Scott
Old 17th Oct 2018, 6:49 pm   #53
Colourstar
Colourstar's Avatar
Worth a try Malc. I'll do that and report back.
Steve.
Old 19th Oct 2018, 10:47 pm   #54
Colourstar
Colourstar's Avatar
Well, some unexpected good news. I ran 30v through the (potted) overwind for a couple of nights, so a good 16 hours worth of gentle cooking.
Popping it back in the set and the EHT now holds steady. The set previously only managed about 3 minutes before the EHT died off.
Just a shame the tube is pretty clapped out
Steve
Old 19th Oct 2018, 10:57 pm   #55
Colourstar
Colourstar's Avatar
No, hang on - it's all gone pear-shaped! Although the picture showed absolutely no signs of distress, a pungent pong after about ten minutes suggested all was not well. Time to power off. Sure enough the overwind was getting very hot again.
I don't think this one wants to live....
Steve
Old 25th Oct 2018, 5:56 pm   #56
Welsh Anorak
I imagine you could fit a doubler or tripler? You'd need to experiment with the tuning/EHT however but it might be worth it. Then you'd just need a tube...
Glyn
Old 25th Oct 2018, 7:22 pm   #57
Colourstar
Colourstar's Avatar
Yes a tripler would appear to be the way to go Glyn. Maybe the poorly LOPT is making the crt look worse than it is. It may even wake up a bit with prolonged use.
Steve
