25th Aug 2018, 4:27 pm | #1 |
A few photos of the AVO CT160A/1 Valve Tester Adaptor Unit for the AVO160A
Here are some photos of the AVO CT160A/1 Valve Tester Adaptor Unit for the AVO160A.
/Martin
Martin, Sweden |
25th Aug 2018, 4:32 pm | #2 |
Re: A few photos of the AVO CT160A/1 Valve Tester Adaptor Unit for the AVO160A
And some closeups and also of the insides.
The ferrite beads are found on the wires in the loop but on the wires going to the connector for the top cap leads there are no ferrite beads so the ferrite bead that is placed inside the black rubber shroud on the top cap lead has to be present here to dampen oscillations. /Martin
Martin, Sweden |
25th Aug 2018, 4:35 pm | #3 |
There was also one page stuck beneath the elastic band on the inside of the top cover.
Maybe it can be of help to someone. /Martin
Martin, Sweden |
