Old 17th Oct 2018, 9:10 pm   #41
M3VUV51
Default Re: G & E Bradley CT-471
i just tried 2n3096 pnp silicon transistors in my amp board,in place of the oc170 trannys ,still got the oscilations but not so bad on the ohms scale but at least it goes to the right when i short the leads now,cant set the zero tho on ohms.
im going to birketts in the morning,may get another meter and see what germainium pnps he has
M3VUV51 is offline
Old 17th Oct 2018, 11:33 pm   #42
Sinewave
Sinewave's Avatar
Have you gone through any other fault finding?
I was hopeful that the famous tin whisker was the problem, but there appears to be other issues, I'm going to take a good look through the circuits and make some measurments and see if the voltages on the schematics are correct or not when I measure them to see if I can pin point some issues.
It might help me understand the theory behind this meter to establish what should be happening.
Avometer, vintage Fluke and Marconi collector. Also interested in vintage Yaesu and KW.
Sinewave is offline
Old 18th Oct 2018, 1:37 am   #43
M3VUV51
to be honest im finding reading the schematic a nightmare,so many wafer switches!,just slowly working on checking components voltage rails etc,ive so far changed nearly every electrolytic,may start checking for of spec resistors,i find lack of test points an issue,from a repair point of view the manual is crap i find!,regards Paul.
M3VUV51 is offline
Old 18th Oct 2018, 11:14 pm   #44
Sinewave
Sinewave's Avatar
So if my transistors are marked as VT, I take it I'll be using the incorrect drawings if any are market TR on the drawings?
Sinewave is offline
Old 19th Oct 2018, 1:20 am   #45
M3VUV51
Don't fret, the transistors are all marked "VT" same as all the diodes are marked "MR", any joy with it yet? I'm still doing battle, I've got 6.3 volts on the 20 volt rail, just trying to see what's dragging it low!
Regards, M3VUV.
M3VUV51 is offline
Old 19th Oct 2018, 2:08 am   #46
Sinewave
Sinewave's Avatar
I went through the amplifier board tonight, checking the reactance of the caps with my scope, most seemed pretty good. C111 was open, so replaced that with a poly film cap for now.
The meter appears to respond on DC current, though only on the lower ranges and it the readings don't appear to correlate with what I'm feeding it, but it's a responce I've not seen before.
Also, noticed a high pitched whine, typical of RF type equipment, not noticed that before.
I can't really see much else going on with the amplifier board, but there's more to do.
I should also do some of the DC rail checks like you're doing.
Sinewave is offline
Old 19th Oct 2018, 5:13 am   #47
M3VUV51
Well I don't know if it's progress but I changed all the OC170 transistors for 2N3906 silicon ones just to see what happened. I notice if I lift the gate of the FET, if I touch it with my finger it pegs the meter hard, that's on the check zero position and the + position. If I put it in the negative position, it slams the meter hard to the left, well it looks like at least the amp's working. Still won't measure anything with the gate of the FET back in the board though and with the FET gate connected the needle oscillates. I'm starting to think it's pointing towards the chopper circuit. Also while messing about one of the legs on VT21 was broken where it exits the case of the transistor, looked like corrosion ,looked fine at a glance though!
It's 5.00AM now so gonna hit the sheets!
M3VUV.
M3VUV51 is offline
Old 19th Oct 2018, 8:38 am   #48
Sinewave
Sinewave's Avatar
There doesn't appear to be a FET in mine and according to information, that is the case for the earlier 471C as my serial number also confirms that.
FETs fitted after serials BGB 2329.
Something along those lines, so there are some differences to ours. My serial is BGB1973XF.
Sinewave is offline
Old 19th Oct 2018, 2:55 pm   #49
russell_w_b
russell_w_b's Avatar
Check your battery negative (earth return) supply is contiguous around all the boards and the board frame. Of the two CT471s I've fixed, the first one had a coruscating flicker on one of the ranges.
A broken earth return is all the problem was; I was lucky!
Regds,
Russell W. B.
G4YLI.
russell_w_b is offline
Old 19th Oct 2018, 7:33 pm   #50
M3VUV51
Worth a look.
M3VUV51 is offline
Old 19th Oct 2018, 9:00 pm   #51
russell_w_b
I would also go bit mad with digital photos prior to diving in there, as it's jolly easy to inadvertently dislodge wires from that nightmare of a board arrangement!
Regds,
Russell W. B.
G4YLI.
Old 19th Oct 2018, 9:24 pm   #52
Sinewave
Sinewave's Avatar
It's something I should look at. I did have the flicking on the scale until I replaced the tin whisker affected transistors. I did notice on another thread that someone had a -ve issue which was the only fault.
I've been spending a lot of time this evening with the schematics, seperating the different functions of the circuits.
I'm somewhat happy with the amplifier board, so next it's the chopper and the power supply board, as well as checking all of the groundings.
Sinewave is offline
Old 20th Oct 2018, 12:42 pm   #53
M3VUV51
well i popped into birketts yesterday,i picked up a bag of ac128 transistors 50 for a quid!,ive checked them and all good,there nos,the only differences i can see is the gain is 40 min as opposed to 150 and transition frequency is 1mhz as opposed to 150,otherwise they seem to better the oc170 on specs,i may try those in it and suck it and see!.m3vuv.
M3VUV51 is offline
Old 20th Oct 2018, 11:39 pm   #54
Sinewave
Sinewave's Avatar
I've made some tests to the amplifier board, checked the 20v rail, getting 19.3v so that's pretty good. 2.4v on the 2.5v rail, so that's pretty good. So, amplifier board should be ok then, unless there's something else on there which I've missed.
Onto the next boards......
Sinewave is offline
Old 21st Oct 2018, 12:03 am   #55
Sinewave
Sinewave's Avatar
Originally Posted by m3vuv51 View Post
well i poped into birketts yesterday,i picked up a bag of ac128 transistors 50 for a quid!,ive checked them and all good,there nos,the only differences i can see is the gain is 40 min as opposed to 150 and transition frequency is 1mhz as opposed to 150,otherwise they seem to better the oc170 on specs,i may try those in it and suck it and see!.m3vuv.
Have you replaced any mustard caps?
Sinewave is offline
Old 21st Oct 2018, 1:22 am   #56
M3VUV51
no mine seemed ok.
M3VUV51 is offline
Old 21st Oct 2018, 2:27 am   #57
M3VUV51
just wondering about the high pitched whine you hear,i would think thats from the chopper transformer,it should oscillate at 550hz is it that you can hear?
M3VUV51 is offline
Old 21st Oct 2018, 9:00 am   #58
Sinewave
Sinewave's Avatar
It could be.
Some of the caps which were ok for ESR are a bit leaky, but I don't have replacements for them all.
I think some of my capacitors in stock which are new are leaky. Perhaps they've been sat on the shelf for too long. I've only in stock what was the remaining amount of a minimum purchase. So I might have to get buying again.
Sinewave is offline
Old 28th Oct 2018, 11:28 am   #59
Sinewave
Sinewave's Avatar
Power supply seems ok. 12v cal check is working.
Sinewave is offline
Old 28th Oct 2018, 5:38 pm   #60
Sinewave
Sinewave's Avatar
So, what's happening now and I don't know why, as I have no idea how these things work is....
on DC current, on the 0.4 range I get meter movement, but the reading doesn't correleate at all with what I'm sending it.
The same on DC volts, on the 0.4 and 1.2 range.
So I need to work out why that is and why still nothing on any other range.
Though if I go to AC, the needle moves around to the centre and floats about a little.
Sinewave is offline
