9th Jan 2021, 2:08 pm | #21 | |
Re: HMV 2320 capacitor polarity
On advice i replaced the C61 with a 500v 100microfarad with the negative replacing the wide negative. and the C60 with 2 x 400v 68 mf with the negative leads together to the wide negative and the positive legs to the 2 other terminals. |
9th Jan 2021, 2:13 pm | #22 |
They're definitely old/used ones shown in the first pictures.
9th Jan 2021, 2:28 pm | #23 |
Yes they are the old ones that came out, replaced with the photos attached.
When testing this was when the resistor started to smoke and get VERY hot so i replaced them with the old caps again, but now that resistor is still smoking and getting very hot. I tested its resistance and its coming up as ok. So I'm abit confused and not sure what to do next. |
9th Jan 2021, 2:35 pm | #24 |
So the resistor is fine, albeit a bit cooked, so you've definitely got another fault somewhere. With the set disconnected from the supply you need to do some resistance checks further along the HT line to deck to see what's dragging the supply down and drawing too much current and cooking that resistor.
9th Jan 2021, 3:12 pm | #25 |
Yes would be good to see photo of the new replacements that were fitted before he refitted the original ones.
David |
9th Jan 2021, 3:14 pm | #26 |
I've just looked at the circuit and it's a strange arrangement that I have to say I'm not immediately familiar with in a bog standard radiogram type thing. I'm only guessing, but I think it's possible that you've introduced a man made fault somehow, perhaps you connected the replacement capacitors the wrong way round and it's blown something else up. I would check all four diodes of that bridge rectifier and carefully check all your work against original photos that you "hopefully" took before you began.
9th Jan 2021, 3:15 pm | #27 |
9th Jan 2021, 3:44 pm | #28 |
Is it me or am I missing something here, but we're talking about two capacitors, C60 and C61. However, the OP is describing 3 separate capacitors connected to three separate positive terminals. The pictures of the original capacitors clearly show 3 capacitors, 2 in one can and 1 in another can - that adds up 3, so where's this other capacitor?
9th Jan 2021, 3:46 pm | #29 | |
Lawrence. |
9th Jan 2021, 3:49 pm | #30 |
9th Jan 2021, 3:53 pm | #31 |
David |
9th Jan 2021, 3:56 pm | #32 |
I can't see how he would have connected the new capacitors the wrong way round as the negative is marked and on the three legged one it would be obvious anyway.
9th Jan 2021, 3:58 pm | #33 |
9th Jan 2021, 4:17 pm | #34 | |
David |
9th Jan 2021, 4:18 pm | #35 |
11th Jan 2021, 4:06 pm | #36 | |
14th Jan 2021, 12:22 am | #37 |
To check the bridge rectifier diodes it is best to disconnect the external wiring/connections.
David |
