Old 9th Jan 2012, 8:11 pm   #81
6AL5W-Martin
Default Re: Oscilloscope Collection / Junky
happy new year
Tek 310A Dual Beam Oscilloscope...
greetings
Martin
6AL5W-Martin is offline
Old 9th Jan 2012, 8:21 pm   #82
6AL5W-Martin
Tek 515A (the new case one)
the painting Co made a mistake in the color selection. May be I will repeat that to get a true türkis ( ~RAL6015, Tek blue). But it looks very nice, my self made Case...
greetings
Martin
Old 9th Jan 2012, 8:34 pm   #83
HamishBoxer
HamishBoxer's Avatar
Yes,i would need a list as well with all that gear!
David GM8JET
HamishBoxer is offline
Old 9th Jan 2012, 8:52 pm   #84
Craig Sawyers
Craig Sawyers's Avatar
For anyone interested, I got Tek blue colour and matt texture matched some years ago by Paints4u. I have no idea whether they still have the formulation on file, but anyone interested drop me a PM and I'll look out the details.
I got it both in spray cans, and in a tin with the correct thinners for paint spray application.
Craig Sawyers is online now
Old 12th Jan 2012, 12:20 am   #85
Richard984
Yes, you cannot have too many 310s.
Richard984 is offline
Old 14th Jan 2012, 1:11 pm   #86
6AL5W-Martin
my next restoration will be a Tek 305DMM
it have a bad HV module, the spare part is on the way from sweden.
greetings
Martin
Old 30th Jan 2012, 8:36 pm   #87
6AL5W-Martin
I have still a problem to fix this 305DMM...
I found yesterday Tek 310A. (I love to restore tube Tek)
greetings
Marti
Old 31st Jan 2012, 7:59 pm   #88
geoff_n
Oscilloscopes are like landrovers: you always end up with more than you need.
I've got four
My best one is a Gould 4030 DSO
the reserve one is a Scopex 4D10B which I have had from new
and the other two are just taking up space
one is a sevicscope type D31 in need of some attention
I think the other one is a Tek but the label is missing. It is transistor, has a central modual with a plugin unit either side
the central modual is numbered 7200 Display unit.
to the left is a two channel input numbered 7212
And to the right is a timebase numbered 7202
What is it?
also it has a 6 pin plug in the back for the mains input. Does anybody know what the connections are and where I might get a suitable socket?
I rescued it from somewhere with one of the side moduals bent, straitened it out, but have never tried to put power on to it.
Geoff
geoff_n is offline
Old 31st Jan 2012, 8:19 pm   #89
Craig Sawyers
Er - I'm at 17 Tektronix 'scopes and counting. And that is the tip of a very large test equipment iceberg. My wife, as I often remind her, is a saint.
Craig
Old 31st Jan 2012, 8:59 pm   #90
cmjones01
What is it?
Interesting. That doesn't sound like any Tektronix I've ever heard of. Any chance of posting a photo? The only '7200' scopes I can see on Google are by LeCroy, and are (relatively) modern DSOs. I'm curious.
Chris
cmjones01 is offline
Old 31st Jan 2012, 9:18 pm   #91
glowinganode
glowinganode's Avatar
Sounds like a Dynamco, dual trace and delayed sweep plug ins.
Rob.
We have done so much, for so long, with so little, we are now qualified to do anything with nothing.
glowinganode is offline
Old 31st Jan 2012, 10:54 pm   #92
geoff_n
There should be a photo attached to this reply
As you can see it's quit a dinky thing quite portable
If this one is succesfull I will do a couple more .
Geoff
geoff_n is offline
Old 31st Jan 2012, 11:17 pm   #93
geoff_n
I've cropped the two side moduals out of the original photo so as to get the detail.
There's a calibration due label for june 1980 and I think it is British made.
Name:	sweep modual.jpg
ID:	62015   Click image for larger version
Name:	Amplifier modual.jpg
geoff_n is offline
Old 31st Jan 2012, 11:43 pm   #94
cmjones01
That's definitely not a Tektronix. I agree with Rob that it's a Dynamco.
Old 1st Feb 2012, 12:08 am   #95
glowinganode
Definitely Dynamco, this was the follow on from the popular 71xx series.
Rob.
Old 1st Feb 2012, 9:19 pm   #96
Renato65
Renato65's Avatar
I'm also blessed with a saint that can tell when a new addition to my inventory arrives. Got to learn and keep the car boot closed.
Cheers Craig
Renato65 is offline
Old 2nd Feb 2012, 6:20 pm   #97
WME_bill
Dynamco 7200. A very niece little portable scope, with 7 x 5 screen, to 15 Mhz.
Manual is dated 1969. Also appears as Post Office type 14A, with dual trace, twin TB. Priced in March 1973 at £435 for single TB, and £485 for twin TB. Particularly good small Brimar tube with mesh pda; D10-210, or GEC/MOV 974W.
Geoff_n asks about the power connector. It is a 6 pin Bulgin type P427 chassis male socket, for mains (A= line, B = neutral, C= earth) and from the add-on DC converter (D = AC,E = earth, F = AC, being 24-0-24V or so at 80Hz). Pins are usually marked, but they go from A in order, counting clockwise from the indent, looking onto the P428 cable female plug. A quick check with the ohmmeter will confirm. A to B, via the fuse and on/off switch to the transformer primary. Changing the mains setting 110/250 will change the resistance. C and E to chassis. D & F go to the secondary windings on the transformer, part of the winding which feeds the 20V bridge rectifier for the +-20V rails. Bill m0wpn
WME_bill is offline
Old 3rd Feb 2012, 11:18 am   #98
Craig Sawyers
There are many and various tricks. Possibly the most effective are:
(1) Sneak it in, and set it up. When the inevitable question is asked, the response is "Had it for ages - surprised you haven't seen it"
(2) Use the existence of an overflow lock-up. "Just pulled it from the lock-up to restore"
Of course the awkward question that is difficult to answer is "Now - where are you going to put it"
Craig
PS she also reminds me that there is a fine dividing line between "hobby" and "mental illness". I remind here that it could be worse - I could be into military vehicles or traction engines.
Old 3rd Feb 2012, 8:12 pm   #99
geoff_n
Thanks Very much to Bill for the info on my Dynamco and to the other lads who helped identify it.
I will have a go at getting it going soon,but I shall have to reform some caps before I power it up.
The low voltage AC input could be quite usefull. I sometimes need a scope in odd places such as a farmyard or a quarry. so the ability to run the scope from the Landrover battery would be better than trying to use the often dodgey mains in a farmyard. I tried using the Gould on an inverter once and got a shock everytime I touched it. So I soon gave that up.
Cheers for now
Geoff
geoff_n is offline
Old 16th Feb 2012, 9:34 pm   #100
6AL5W-Martin
Wink Re: Oscilloscope Collection / Junky
Tek 310A #100676, made in Guernsey C.I.
with some little problems.
greetings
Martin
