29th Mar 2020, 8:31 pm | #1 |
Worth salvaging trimmer capacitors? (Actually IF Transformers).
At least, I think that's what these are. I'm stripping out some old boards and wondered about the efficacy of these and whether it's worth retaining them. The hardware, capacitors and resistors I can use, but I haven't delved into RF yet.
29th Mar 2020, 8:34 pm | #2 |
Re: Worth salvaging trimmer capacitors?
Those look like IF transformers (adjustable inductors)
Lawrence. |
29th Mar 2020, 8:35 pm | #3 |
The picture shows IF cans
Yes worth saving if your going to the trouble Cheers Mike T
29th Mar 2020, 8:37 pm | #4 |
Thanks chaps. Of course, shielded inductors. Thanks. I'm having isolation fun with the Magnastat!
31st Mar 2020, 3:03 pm | #5 |
Re: Worth salvaging trimmer capacitors? (Actually IF Transformers).
Careful with those, I recall they have a paxolin/srbp base and when heated the pins will pull out if you are not very gentle. Sucking or wicking all solder off before attemting any 'pull' is recommended (at least by me).
Andy G1HBE. |
31st Mar 2020, 8:49 pm | #6 |
I would cut the old board up with the coils still in it and make each IF coil into an osciillator tuned to one of the common IF frequencies and fit any old transistor out of a modern throw away gadget in .
Some people just keep the slugs out of them if they have not been chewed up. |
