25th Mar 2020, 3:16 am | #21 | ||
Re: Solution for slippery croc clip covers ?
Mike |
25th Mar 2020, 10:26 am | #22 | |
I got them off eBay from China a while ago. (They may be available in the UK at a much higher price). The problem with eBay - especially when sourcing from China - is that a search for something as simple as '35mm crocodile clips' (or 'croc clips') will bring lots of results, but not quite what we want. Also, whereas in the UK and America, generally 'croc clip' means small clips and 'alligator' means large clips, in 'Chiglish' the search may well bring up large 'croc clips' small 'alligator clips', and may include croc style hair grips. The also seem to think that 'clip' and 'clamp' are synonyms', and some may argue that they are. So I accepted your 'mission' for me to answer your question and after a jolly good furtle around in the swamp searching for 'crocodiles, alligators, clips, clamps, test clips, red black' using different search strings. At last, I came up with a result, which includes all of those words in the description! Maybe not s daft because any of those terms in a search string might lead to that link eventually: "32pcs Alligator Clip Terminal Test Electrical Battery Crocodile Clamp Red Black". They're £1.80 post free on a slow boat from China - expected delivery, Tues 5 May - 1 June. (@ 2.5p each, worth the wait!). The spec states: Specifications: - Type: Battery Alligator Clip - Material: plastic+metal - Fit Cable Size: 3 x 2mm / 0.1" x 0.08" (L*W) - Overall Size: approx. 35 x 14 x 8mm / 1.4" x 0.55" x 0.3" (L*W*H) - Max. Open Width: approx. 11mm / 0.4" - 32pcs car battery alligator clip, features metal construction, red black soft plastic coated insulated connector end - Spring loaded clamps withstand the pressure, easy and safe to use, ideal for auto car, vehicle, truck, etc Package Contents: 32 x Alligator Clips (16 Red + 16 Black) https://www.ebay.co.uk/itm/32pcs-All....c100752.m1982 The pic below shows the clips - one with a shroud pulled off to show the soldered joint. The other clip in the pic is of a useless shiny plastic 'joke clip' which - when you press to open will swivel round inside the shroud. In my experience, other similar clips with duller 'rubbery' plastic harden off after a year or two and are hard to open. Hope that helps.
25th Mar 2020, 11:53 am | #23 |
David, you're a star! I'm going to get a load of those ordered straightaway. Then I can ditch those "practical joke" slippery shrouds.
Mike |
25th Mar 2020, 12:44 pm | #24 |
I think I'll be getting some of those and making my own leads, David. The ready-made ones from rallies etc are handy and cheap, but a right royal pain with their slippy-slidey shrouds. Then they go rock-hard and won't allow the clip to open. The cheap, skinny wire tends to go o/c at the ends too.
And for some reason they baulk at 10 Amps.....
Andy G1HBE. |
25th Mar 2020, 6:05 pm | #25 |
Super, David Get in quick, there's only 93 sets left from that dealer as I write!
- Julian It's good here |
25th Mar 2020, 6:08 pm | #26 |
Like others I ditched the joke slippery clips a while ago and now use the concoction shown in the attached photo as a result of a couple of Lidl's specials last year. Lead is soldered.
Alan |
25th Mar 2020, 6:14 pm | #27 |
No Longer a Member
I made the mistake of buying clips from a Chinese supplier. I could not get any grip on them at all. I now use clips made by Mueller Electric purchased through Farnell. Good value and no slipping.
25th Mar 2020, 6:58 pm | #28 |
I just tie a knot at end and it helps.
25th Mar 2020, 9:14 pm | #29 |
Love the solution!
26th Mar 2020, 12:29 am | #30 |
Would a red lead have more knots?
(Nod to the convention of "More knots is positive" if you only have one colour of hookup wire )
