Old 6th Mar 2020, 10:11 pm   #1
record man
Default Swan Mayfair CH480 percolator
Does anyone know how the button on the front works?
Many thanks Steve
record man is offline
Old 7th Mar 2020, 1:35 pm   #2
duncanlowe
Default Re: Swan Mayfair CH480 percolator
I would hazard a guess at it being a reset for an overheat cutout. So you do nothing unless you run the thing without water, then have to press to reset.
duncanlowe is offline
Old 7th Mar 2020, 7:55 pm   #3
Graham G3ZVT
Graham G3ZVT's Avatar
Someone with a current online auction listing describes it thus:
"A quite advanced model in its day with a manual on/off cut-off switch to the front"
However, I would expect it to be a boil-dry protection cutout.
Graham.
G3ZVT
Graham G3ZVT is offline
Old 7th Mar 2020, 9:48 pm   #4
G8UWM-MildMartin
Duncan and Graham are absolutely right.
(I have one in regular use.)
G8UWM-MildMartin is online now
Old 8th Mar 2020, 12:37 pm   #5
record man
Thanks all very helpful, just to confirm that there is no auto stop when right temp. is reached.
Old 8th Mar 2020, 2:30 pm   #6
Graham G3ZVT
Our '70s percolator reached an orgasmic frenzy as it near-boiled, then appeared to switch the element to a low-power setting that just kept the brew hot, so I would expect another thermo-switch in addition to the safety cut-out.
Let's see what Martin says.
Graham.
G3ZVT
Old 9th Mar 2020, 9:19 am   #7
record man
Ok thanks Graham i will see what Martin comes up with.
Steve
Old 9th Mar 2020, 10:25 am   #8
G8UWM-MildMartin
There's nothing posh like that on these, just the 400-watt element and the safety cutout.
You simply unplug it after it has been percolating for a few minutes.
Adjust the time by trial-and-error according to taste and coffee blend, and enjoy the coffee before it goes cold!
Old 9th Mar 2020, 4:39 pm   #9
record man
Ok thanks everyone it's much appreciated.
Steve
