Old 20th Jan 2020, 12:44 am   #1
Uncle Bulgaria
Uncle Bulgaria's Avatar
Default 'Ferrite Pot Core Pairs'?
Ahoy,
I'm considering making the capacitor leakage tester and reformer featured in 'Everyday Practical Electronics' of September 2012. One of the parts it requires is a small, PCB-mount transformer ("ferrite pot core pair, 26mm OD, with bobbin to suit"), with instructions on how to wind it. The parts needed are available from Jaycar in Australia (LF1060 and LF1062 for the accompanying bobbin) where the design is from, but similar search terms come up blank around here.
In general, threads I've found on transformers on this forum suggest that the days of buying parts for one's own winding are gone for whatever reason. The Variable Voltage Technology company mentioned in another thread has broken links for their 'kits' page (I was interested in making some for a Mullard 5-10 possibility with a friend).
Are parts for this little PCB transformer around, and in 2020 are there any options for buying new laminations and parts for larger projects?
Uncle Bulgaria is offline
Old 20th Jan 2020, 1:12 am   #2
G0HZU_JMR
Default Re: 'Ferrite Pot Core Pairs'?
It might be worth posting up any info about the winding and the inductance and if it is designed as a gapped core.
The equivalent pot core might be something like this '25mm' 3H1 core below but I think more information is needed.
I think the pot core pair below is specified as ungapped.
https://uk.farnell.com/ferroxcube/p1...ngdom%2Fsearch
Regards, Jeremy G0HZU
G0HZU_JMR is offline
Old 20th Jan 2020, 9:21 am   #3
MrBungle
MrBungle's Avatar
Jaycar parts look like the standard mullard jobs. I’ve got a whole box of mullard/philips/ferrox pot cores and bobbins floating around somewhere. I’ll dig it out this evening and see what I can find. May be a match!
If I don’t reply please PM me so I don’t forget. Got busy day with work unfortunately first
Edit: part is philips FX 2240
MrBungle is offline
Old 20th Jan 2020, 6:37 pm   #4
Aub
Aub's Avatar
FX2243 was the pair that everybody wanted in the early seventies, for the PE Scorpio electronic ignition project 😄
Life's a long song, but the tune ends too soon for us all.
Aub is offline
Old 24th Jan 2020, 6:32 pm   #5
Uncle Bulgaria
Thanks all. I haven't yet decided to do the project or not (though a reformer/tester would be a good wheeze).
G0HZU_JMR - the quoted text is all the magazine gives as a specification - the diameter. Not having gone through the circuit I'm not sure what the transformer does. Thanks for the Farnell link. I did have a look but as I've never wound one before I wasn't sure what components are required, what they look like or how they fit together. Most of what I've read concerns the larger E I type.
Is winding transformers just something not done these days? Is there anywhere to buy the relevant parts (particularly for high-voltage valve stuff)?
Aub - My MGBGT came with electronic ignition, so no need for that project just now! However, the battery has just gone so some electrical work is required.
MrBungle - Thanks. Did you find something? I'm away this weekend but I'll be back on next week and will decide whether I'm going to make this. At the moment I'm awaiting a meter for the ESR meter there was a long thread on in about 2011. I've done the perfboard and am now considering a case...
Old 24th Jan 2020, 8:24 pm   #6
MrBungle
MrBungle's Avatar
Still haven’t had a minute to attack the cupboard yet. Will let you know when I do. Hopefully tomorrow if nothing goes wrong
MrBungle is offline
Old 24th Jan 2020, 8:32 pm   #7
kalee20
I'm pretty sure Farnell and RS stock ferrite cores, bobbins, clips, wire, tape. Yes, winding is done, though not so often by hobbyists so the hobby suppliers don't stock much stuff, and the industrial suppliers aren't so geared up for the odd £10 order.
kalee20 is offline
Old 24th Jan 2020, 10:19 pm   #8
MrBungle
MrBungle's Avatar
RS tend to throw out a situation where you can buy two ferrite cores for £1 and then you have to buy a bag of 100 bobbins for £45 or something ridiculous.
I decided to take the cupboard to bits entirely and reorganise it this evening but the box of ferrites is completely missing. Not sure what happened there. I will ask Mrs Bungle if she’s moved of filed any of my stuff when she gets back from getting trashed
MrBungle is offline
Old 24th Jan 2020, 10:30 pm   #9
MrBungle
MrBungle's Avatar
Ok it appears, as they say in America, that I am a dumbass. The box has been sitting in front of me on my desk shelf for the last month and I though it was something else. After writing this I will go sit in the corner and don the dunce hat.
I dug around and typically I only have FX2242 and FX2241 parts. Both have significantly different AL value according to databook
Also have a bunch of LA4130, FX3438 and FX3440 cores if they are any use.
Photo included...
MrBungle is offline
Old 25th Jan 2020, 2:39 am   #10
Chris55000
Hi!
I might be able to offer a tip:–
I don't know how many he has – I bought one – but enter:–
"Core fi26 AL5000 M4" in an eBay search –
. . .this is a 26–27 mm pot core pair, gapped, with a base and pins – you can dismantle this to remove the pins and then place the assembly in hot water to separate the halves (suggested by seller) – only snag is the postage, £5.50 – is about five times the cost of the part, as it's from Poland!
Compared with paying £30 in p & p for Jaycar to import the thing from Oz or the daft multiple quantities RS, Farnell & Mouser etc., expect you to buy, it's about the cheapest you'll get as a one–off!
You do have to strip the old winding off it's bobbin tho!
Unfortunately EPE have deleted PCBs before Jan 2013 from their online store list, so I don't know if you can still buy EE 861 from them to make this! (I bought mine direct from Silicon Chip – it costs about £17.60 including postage – at the time I ordered mine the SC website showed a stock of 8!)
S.C. supply the F.P. artwork and the hex. free with each PCB order!
Chris Williams
PS!
The original plastic storage box used for building the prototype is still fairly readily available on eBay!
Chris55000 is online now
Old 31st Jan 2020, 1:23 am   #11
Uncle Bulgaria
Chris55000 - on the EPE online shop all the PCBs appear to be available: https://www.electronpublishing.com/p...former-tester/
I was toying with just making it on perfboard, or perhaps some good old tagstrip, but it would certainly be easier to use their PCB!
I thought a nice wooden box with a hinged transparent lid for the capacitor in question (some brass plates, too?) would be more appealing than the plastic box they built it in, so I'd be investigating that once I've sharpened my dovetail saw...
MrBungle - I don't know enough about the subject to see if those parts are suitable, but many thanks for looking through your box. Or perhaps Mrs Bungle should be thanking me for providing the cupboard-sorting impetus!
I've attached the diagram so you can see how the circuit functions. The transformer is part of the step-up from the DC supply, and the winding instructions are included.
Old 31st Jan 2020, 9:12 am   #12
MrBungle
MrBungle's Avatar
Ooh that’s a nice simple little circuit. There’s not much to go wrong. You can probably use anything such as a reasonable sized material 43 toroid for that. I’d just stack a couple of FT82-43’s and use that. Be aware though the switchers built like this are quite explodey. Use a current limited supply if you can on power up and wear safety glasses. IRF5x0 devices go with quite a bang. This usually happens when the Vds max voltage is exceeded or the Ic max is exceeded. Both of these can happen depending on the loading of the secondary and when the oscillator stalls while switched on. I’ve been abusing them as switching supplies and RF power amplifiers for about three years now
If try and keep the layout around the gate drive circuit fairly tight otherwise it can turn into an unexpected and violent suicidal oscillator.
Here’s one I built about 3 years ago to do the same task (leakage check). This was only 200V. I used 555 and LM311 to control it instead of the 34063. Not very accurate or efficient (45%) but it worked with what was on hand.
And yes it did indeed help with the cupboard sort out and that did indeed help with Mrs Bungle
MrBungle is offline
Old 1st Feb 2020, 9:51 pm   #13
Uncle Bulgaria
Thanks for the thoughts - and for that Manhattan delight!
I'm afraid about 3/4 of what you wrote went over my head with a great whooshing sound. I can follow the circuit as I read the accompanying text, but I haven't yet reached the stage where I can explain it to someone else.
I hope they've considered the exploding aspect, as they do make some effort to drive home the safety aspect of the design!
Are any of your box parts suitable for this? I can't see that it's too critical as it's just a step up transformer as far as I can see...not exactly a phono coupling stage!
I'm impressed at the level of ingenuity here. For those of us not trained in electronics, the ability to fashion a useful circuit from scratch is quite awesome.
I've had a look for "FT82-43" and end up with some ferrite rings. Are you proposing I just wrap the wire around that and let it be, without the associated surrounds, pins and cores?
Old 2nd Feb 2020, 3:25 pm   #14
John_BS
John_BS's Avatar
I've had a dig around and found some data on the cores.
The FX2240 is ungapped, AL value circa 4000 to 8000 nH/t
The Neosid 26 -16 transformer core is a similar spec.
The reformer article has just the centre-limb gapped to 0.06mm (i.e. 3 thou,) which doesn't sound very hygenic, so i'd be inclined to shim the outer rim as well. It looks like the gapping reduces the AL to about 1000nH/t.
Please find a scan of the relevant data from me little archive!
John
John_BS is offline
Old 2nd Feb 2020, 6:23 pm   #15
Radio Wrangler
Radio Wrangler's Avatar
Ferrite is rather brittle. The core in that article is not gapped, which some manufacturers code as oL in their markings (EG Siemens/Epcos)
Shimming the centre post does indeed gap the centre, but it also gaps the outer as the stuff is so stiff. So you get two gaps in the magnetic circuit. With the gap, the AL value of the core will be much lower than the ungapped use would give, but also the saturation current is improved.
They make ready-gapped cores where just the centre post is ground (below the level of the outer) and this makes the core self-shielding. Helpfully, they printed the AL values on them too. Watch out though, some cores were ground equally on both halves, others got the whole gap on one half only. Usually these had a nut for an adjuster glued in on the non-ground half. You could bodge an ungapped core from two bottom halves!
Radio Wrangler is online now
Old 2nd Feb 2020, 7:18 pm   #16
MrBungle
MrBungle's Avatar
Mostly me ranting about the exploding fragility of MOSFETs
Anything will probably do the job here. I'm not sure if any of the parts I listed were good. I don't have data for them off the job of my head. I can probably find out but am unfortunately stuck in a hotel on my laptop at the moment
On the FT82-43, yes you pretty much just wrap the wire around it. The toroidal cores confine the majority of the magnetic field inside the core which means a lot of shielding isn't required. On low power ones i usually just use a glue gun to stick them to the board. I've made a few like that as they are cheap and easy to reproduce. After digging around in the bowels of this laptop i found a picture of a simple bipolar supply which was made using a Royer oscillator and an FT82-43. This was specified as 5v in (from USB charger) to +/-15V for an opamp circuit.
These things are repeatable and available in vast numbers for not a lot of money and are quite useful (you can run coax through them a couple of times to make RFI filters too)
MrBungle is offline
Old 30th Mar 2020, 11:38 pm   #17
Uncle Bulgaria
So, isolation means I'm back to this project. I have just removed a load of components from some old boards, including some small transformers that could possibly be re-wound.
As I'm getting from MrBungle, the actual performance figures for this particular transformer are not critical. I just need 10T and 80T on a single wire, which I could get winding on a toroid as in the picture above, linking the centre to the IRF540N.
I have no practical experience with transformers so getting my head around gaps and shims has caused a bit of steam to come out of the ears. I'm off to YouTube now for some video advice, and the Radio Handbook!
Old 31st Mar 2020, 2:48 am   #18
Radio Wrangler
Watch out. A ferrite toroid is essentially ungapped. The article isn't good about specifying the core, but its exploded diagram shows a gapping shim on the centre post.
The core pair together start out with an Al value of 6000nH per root-turn
But this gets reduced dramatically by the fitment of a 0.06mm gapping shim washer
So the effective magnetic path has a cross section of 101 square mm and a length of 36.6mm at a relative permeability of 1200 (minimum)
This gets modified to a length of 36.6mm at Ue=1200 plus 0.12mm at Ue=1
0.12mm because the washer creates two gaps - in the centre post and in the outer ring.
YOu'll need to read up on magnetics design to see what this does but a quick estimate is an Al value of 6000*(36.6/(36.6+0.12*1200))
which comes out as 1216nH per root turn.
Take the number of turns in a winding, square it, then multiply by 1216nanoHenries and you'll be close to the inductance of that winding.
10turns primary, so 10 squared is 100, times 1216nH gives us 121600nH or 121.6uH
The 80t secondary will give 64 times more inductance.
The gapping is very important. It not only brings down the inductances a lot, it also increases the saturation current a lot. It also makes the inductance value more stable. THE BEHAVIOUR OF THE TRANSFORMER IS MORE DETERMINED BY THE GAP THAN BY THE CORE.
You could get away with murder in choosing other coresm, but you need to do some sums to see which will work. Ideally you want a core in comparable material with a comparable effective cross sectional area (or a bit larger) gapped to give an Al of around 1200 nH/root turn.
Old 31st Mar 2020, 8:06 pm   #19
Uncle Bulgaria
Thank you, David!
However, bear with me as I'm still a few steps behind you in knowing what the figures are doing. Let's go even further back to basics as I dredge up my school physics.
What I believe is happening is that the MC34063 is being used to create a switched-mode power supply with the IRF540N. The transformer is being used to step up the high-frequency AC before it's rectified by the UF4007 and returned to the feedback point on the MC34063.
I've looked at the datasheet of the MC34063 to see what they have to say about suggested uses, and they mention an inductor in the 'boost' configuration. Is this what the 10T side of the transformer is? If so, is that impedance the critical factor that will dictate the inductance figures used in David's calculations, and allow me to select a possible core?
I now see that as the frequency is high, the transformer's properties depend on more than the turns ratio. If this is not right, does that mean the transformer will saturate and the output voltage will not be stable or correct? I can guess that the laminated core transformers I attached a picture of will not be suitable.
The datasheet gives a maximum of +6V as a supply for the MC34063, yet here +11.4V is applied. Why?
The single diode seems quite crude and inefficient as a rectifier. Am I right in thinking that the switching from the positive DC supply induces no negative emf, so as the pulses are only positive the diode is suitable rather than requiring a full-wave rectifier?
I'd rather work this out and see if there's something I can lash up than splurge on some little core from Australia, in the spirit of education!
Old 31st Mar 2020, 8:55 pm   #20
ian_rodger
I tried building this circuit (just the inverter part) and found the performance to be very critical of the air gap. I did get it working up to a point but it was temperamental. Cant remember exactly which ferrite cores I used but I could probably dig them out of scrap box and see if you want. In the end I gave up and designed an alternative using a standard 6v 3VA mains transformer. Its documented here https://www.vintage-radio.net/forum/...d.php?t=144420
ian_rodger is offline
