Old 19th Mar 2020, 6:46 pm   #21
David G4EBT
David G4EBT's Avatar
Default Re: Small Hobbyist Wood Router
Excellent end result Brian - mission accomplished!
As to B&Q plywood, most plywood sold by DIY stores is 'construction grade' plywood - not 'furniture grade' which is known as 'birch through and through'. In other words, each ply is birch and of the same thickness. B&Q do sell 'birch through and through', but only in 8' x 4' sheets. Construction grade plywood has a reasonably presentable veneer each side, (usually a light pink/red colour), but thicker and softer inferior coarse-grained plies between the facing veneers.
There are companies who will cut plywood to size - this one for example, will cut softwood ply, marine ply or birch ply, but when we're renovating old radio cabinets, if the radio is of little value, costs must be a consideration.
If you put your dimensions, thickness and type of ply into the price calculator you get an instant quote:
https://www.woodsheets.com/plywood-s...irch%20Plywood
At the gallery at the link below, among the rocking horse pictures at the top there is one of an unpainted rocking horse made from birch through and through plywood, which highlights the muscular contours of the horse:
https://www.rockinghorse.co.uk/hand-carved-horses.html
I've attached a (not very clear) picture showing the two types of plywood.
Hope that's of interest and relevance.
Name:	Plywood types.jpg
David.
BVWS Member.
G-QRP Club member 1339.
David G4EBT is online now
Old 23rd Mar 2020, 10:16 pm   #22
BrianAllen
Completed base for my Bush PB. 12 I am now replacing walnut veneer to the damaged areas: Please note, do not use water based paint/varnish strippers to a veneered cabinet as they may lift the veneer. The product I initially used had to be left on for one hour, which is far too long, so back to quick acting Nitromors.
Thanking you all for help with this little project.
BrianAllen is offline
