5th Aug 2023, 8:29 pm | #41 |
Re: My Hitachi CP1421R smoked
It is unlikely that the replacement IC has failed. They normally 'blow up' when they go like your original one did. Far more likely that there is still something else wrong. You need to check all the peripheral components in the primary of the supply.
5th Aug 2023, 9:47 pm | #42 |
Yep, R804 is dead. It is burned too, but the mark is on the bottom where I couldn't see it. Diodes seem to be ok, despite the torture me and my poor soldering skills have put them through.
10th Aug 2023, 5:25 pm | #43 |
Aand no effect
Except now the IC values are 315 on pin 1 and 0 on all others. |
10th Aug 2023, 6:49 pm | #44 |
Also, maybe it's just my meter but the resistors are supposed to be 0.56 ohm and it's showing 0.8 ohm.
The first one I soldered in had flaked a bit and no longer shows anything on the meter, second seems to be ok. |
11th Aug 2023, 12:06 am | #45 |
And another thing I noticed is that on schematic R804 is a circled zigzag, unlike the other ones. In the part list it's listed as a "fusible", and the one I put in instead is a metal film resistor. Could that be the problem?
I read about it, and it seems that a "fusible" resistor is just a fuse and a resistor in 1, so I guess it isn't a problem? I swear, if this is some kind of "left the lens cap on" issue... maybe I shorted the IC or something? because my hand did slip a few times. |
11th Aug 2023, 12:24 am | #46 |
Fusible resistors are often marked as 'safety-critical', so it's good practice to replace like-for-like.
Check any more that you find on the schematic, as it's not always immediately obvious if they have gone open-circuit without going through and testing each one. Also look on the schematic for anything marked as 'ICP' or 'circuit protector'.
Regards, John |
11th Aug 2023, 1:06 am | #47 |
11th Aug 2023, 10:16 am | #48 |
11th Aug 2023, 10:32 am | #49 |
11th Aug 2023, 1:19 pm | #50 |
Without any voltage on pin 9 the IC won't do anything. So we need to look at where this voltage has gone.
You've checked the feed resistor, so check there's a high voltage at one end and zero at the other. This means it's being loaded down. Coud be the new IC (unlikely) or a diode connected to it which isn't in your diagram. Check for a low ohms reading from pin 9 to earth (Tv off and main capacitor discharged, of course). If you have one then find out what's loading it down. Make sure all diodes have an infinite resistance on your meter's ohms range. Under 1M won't do! Why not get an electric desoldering tool? They aren't expensive and will save you a lot of trouble. Also if you say your soldering isn't the best, check you haven't damaged a track by looking under a magnifying glass with good lighting. |
11th Aug 2023, 5:59 pm | #51 | |
All the diodes have around 2M Ohms. |
12th Aug 2023, 7:37 pm | #52 |
So now I've checked everything in the power supply, and everything is working.
It could be another cap losing its juice, I can't measure capacitance, so I can't see if they are working badly. Though in that case I think there would be some signs of life. It could also be the IC, or some other component. Or some broken/burnt traces. I haven't seen any though, and I always checked if connections are still there. Wouldn't hurt to test one more time, right? |
12th Aug 2023, 8:00 pm | #53 |
The second R804 resistor also flaked and stopped working. Even though the TV wasn't plugged in and caps were discharged.
12th Aug 2023, 10:43 pm | #54 |
Also I can't find this resistor anywhere. I need a 2W 0.56 Ohm fusible resistor, please help.
13th Aug 2023, 8:24 am | #55 |
The exact value is not too critical; the fusible element is quite important. If it were me, I would try putting a 1.5 ohm fusible and 1 ohm 0.75W fusible in parallel. These are easy to get values from the likes of Cricklewood.
13th Aug 2023, 10:39 pm | #56 |
14th Aug 2023, 7:32 am | #57 |
2 0.75W resistors in parallel will equate to 1.5W, which should be OK in this position. And yes, both would need to be fusible resistors though.
14th Aug 2023, 11:43 am | #58 |
14th Aug 2023, 3:16 pm | #59 |
A fusible resistor is just a special kind of resistor designed to go open circuit in a controlled, quick manner. Basically a resistor that doubles up as a fuse. Most are very low values.
If you are fitting an ordinary resistor as a replacement and it is burning up, then you have another fault which needs investigating. |
14th Aug 2023, 7:38 pm | #60 |
