Old 6th Aug 2019, 7:51 am   #1
FIXITNOW
FIXITNOW's Avatar
Default Hacker RP34 Spray painted Help to remove
found this at the boot Sunday for £3 thought it was a black one till I opened it and the inner edges are blue looks like it was spray painted black?
anyone tried removing spray from the vinyl coating ??
what to use
why would anyone would want to make a blue one black
may be the vinyl is poor but better to paint again in blue
ID:	187912   Click image for larger version
ID:	187913   Click image for larger version
FIXITNOW is offline
Old 6th Aug 2019, 3:40 pm   #2
Brettski
Brettski's Avatar
Default Re: Hacker RP34 Spray painted Help to remove
that's a tricky one. What ever you attack it with may distort or melt the rexine . Nail varnish remover might shift it, but it wont be straight forward.
Sorry.
BVWS Memeber
Brettski is offline
Old 6th Aug 2019, 3:48 pm   #3
paulsherwin
paulsherwin's Avatar
I don't think you'll get that paint off, and as you say there'll be a reason why it was painted in the first place. You'll need to live with it, paint it again, recover it, or use it as a donor set.
paulsherwin is online now
Old 6th Aug 2019, 6:24 pm   #4
Tractionist
It all depends what it was painted with - a gentle experiment with cellulose thinners and/or Nitromore's in the most inconspicuous [very limited] location may be instructive. But .... as Bretski and Paul have intimated - you may well have to live with it.
N.B. Another issue is the matter of the rexine backing/padding/foam and timber cabinet sub-straite - the last thing that you want to do is damage or compromise those!
Red to red, black to black. Throw the switch and stand well back!
Tractionist is offline
Old 6th Aug 2019, 6:25 pm   #5
Scimitar
Scimitar's Avatar
I would repaint. Thinners would be the obvious choice but that is likely to damage the material before the unwanted paint comes off.
Scimitar is offline
Old 6th Aug 2019, 7:57 pm   #6
fetteler
fetteler's Avatar
That doesn't look like spray paint to me, the edge between the blue and black is too well defined and the wavy look has something of the hand done to it.
There were special dyes sold for shoes, to me it looks like it's something like that. If so I would try meths. Try a bit on the hidden edges. Other solvents to use are acetone (as has been suggested) or isopropyl alcohol.
I wonder if it was done by someone who just wanted to 'modernise' it? Black was a popular colour in the 80s.
Whatever the colour it's a very nice radio
fetteler is offline
Old 6th Aug 2019, 8:07 pm   #7
mhennessy
No foam padding on the Democrat.
The stuff Hacker used is much more hardy than the usual Rexine used by most manufacturers - when cleaning sets I've used relatively harsh chemicals like IPA with no ill effect. No guarantees, of course, but not much to lose either...
mhennessy is offline
Old 7th Aug 2019, 8:55 am   #8
FIXITNOW
FIXITNOW's Avatar
I will sort out all the different stuff I have to hand and see will report back cheers Vince
FIXITNOW is offline
Old 8th Aug 2019, 12:18 am   #9
fetteler
fetteler's Avatar
It's worth sating that you had best keep acetone and IPA away from the other plastic parts like the tuning scale and knobs... just in case!
Steve.
fetteler is offline
Old 8th Aug 2019, 7:42 am   #10
FIXITNOW
FIXITNOW's Avatar
striped the radio and speaker out of case
And used Graffiti remover FX081250 to get most of it off then Xylene mixed with a dash off washing up liquid for the grained in bits
the blue covering looks to be in great condition
so in all a good result thanks to Hacker using a very durable covering
will need to stick the back edges down as they are now a bit loose and the grill will need a mask and respray
ID:	188034   Click image for larger version
ID:	188035   Click image for larger version
ID:	188036   Click image for larger version
ID:	188037   Click image for larger version
FIXITNOW is offline
Old 8th Aug 2019, 8:21 am   #11
Nickthedentist
Nickthedentist's Avatar
Wow, amazing result, Vince!
Nickthedentist is offline
Old 8th Aug 2019, 9:05 am   #12
Hybrid tellies
Hybrid tellies's Avatar
Great result. As you said its quite amazing to see the quality of the original covering used by Hacker.
Simon
BVWS member
Hybrid tellies is offline
Old 8th Aug 2019, 9:16 am   #13
paulsherwin
Yes, great result. Glad to be proved wrong.
