18th Jun 2007, 8:16 pm | #1 |
Solartron VM1484 True RMS voltmeter
I've just acquired a Solartron VM1484 True RMS voltmeter. It almost works, that is, it fires up and gives a reading within about 25% of what's expected on all ranges. I guess that it's in sore need of recalibrating and probably has a few precision resistors which are no longer precision. In other words, it needs a good going over.
Can anyone help with a service manual and cct diagram or even just setup instructions? Pete. |
19th Jun 2007, 11:58 am | #2 |
Re: Solartron VM1484 True RMS voltmeter
The manual is now available from my web site:
http://home.btconnect.com/gmb Sorry about the quality but the original copy I have turned out to be not very good. By the way, I think this voltmeter may have gone out under different badges too. |
19th Jun 2007, 12:19 pm | #3 |
Thank you very much.
The manual is a lot better than wading in with heroic guesswork. If I come across a better copy, I'll let you know. From the manual, it uses a Weston Instruments patent and Solartron and Weston Instruments were both part of Schlumberger at that time, so I wouldn't be surprised if it was rebadged or built under licence in other countries. Pete. |
