Old 16th Jan 2019, 7:03 pm   #1
G4YVM David
G4YVM David's Avatar
Default I fancy a vintage radio now...
I have been mixing with you lot too long...i Now fancy a vintage radio because they look so good. Ideally I would have one that covers short wave but it seems that these are uncommon in domestic portable style. I have found a unit which takes my eye, untested and sold as is so probably doesn't work. Just wondered what folks thought of this type. Shame no shortwave, but I don't know what does have shortwave. The unit I have been is a Roberts J9871 Radio, like i say, if unknown workingness.
David, G4YVM.
G4YVM David is offline
Old 16th Jan 2019, 7:45 pm   #2
Nuvistor
Nuvistor's Avatar
Default Re: I fancy one now...
I can’t find any details about the radio, there is one on eBay, red, battery valve, can’t see any aerial for it, I would have thought a frame aerial would be used.
Some one on the forum will have seen one.
Edit It is possible a Roberts Junior.
Frank
Nuvistor is online now
Old 16th Jan 2019, 7:47 pm   #3
crackle
Radio Museum lists a few which meet your requirements.
see the attached excel sheet listing some radios from 1950 to 1965.
Book2.xls
Mike
crackle is offline
Old 16th Jan 2019, 7:54 pm   #4
paulsherwin
paulsherwin's Avatar
Actually, most mainstream radios from the late 30s to the late 50s do have SW coverage, though it's true that this is much less common with small 'second set' models and battery portables. The SW coverage is normally fairly basic and intended for use with strong broadcast signals.
paulsherwin is online now
Old 16th Jan 2019, 8:13 pm   #5
snowman_al
snowman_al's Avatar
If you want a Roberts with short wave and valves, look out for the Roberts RMB.
https://www.radiomuseum.org/r/roberts_rmb.html
Alan
snowman_al is offline
Old 16th Jan 2019, 8:25 pm   #6
music-centre
If you can find one the Roberts P5A works well, mains only with Octal valves, a lot less of them around than the RMB though.
Steve.
https://www.radiomuseum.org/r/roberts_unknown.html
music-centre is offline
Old 16th Jan 2019, 9:07 pm   #7
g4aaw pete
g4aaw pete's Avatar
Hello David
as said, there aren't too many battery valve portables with lots of wavebands, which might make finding one a challenge.
The Pye PE94MBQ looks quite impressive. I've only seen two in the last five years. One at auction, and one in a 'curio' shop in Hythe, Kent.
Radio museum has a picture.
Regards
Pete
g4aaw pete is offline
Old 16th Jan 2019, 9:40 pm   #8
G4YVM David
Thanks guys. I'll have a look then probably settle for a good looker with fewer scores on my wish list...
David, G4YVM.
Old 16th Jan 2019, 10:06 pm   #9
snowman_al
snowman_al's Avatar
For better short wave coverage look for an American brand - Zenith and their 'Transoceanic' or Trans-oceanic models. They do come up over here from time to time.
Just an example https://www.radiomuseum.org/r/zenith...anic_r600.html
Old 16th Jan 2019, 10:29 pm   #10
wd40addict
wd40addict's Avatar
No long wave on the valve Transoceanics though.
wd40addict is offline
Old 16th Jan 2019, 11:41 pm   #11
G4YVM David
Yes that's the one. Looks nice don't you think?
David, G4YVM.
Old 17th Jan 2019, 12:01 am   #12
Nuvistor
Nuvistor's Avatar
The frame aerial is concealed under the plastic wrap that goes around the cabinet, you can see the wires going through the cabinet wall in one of the photos.
Convinced it is the Junior, beware of the filaments in the valves, very easily damaged.
Hope you win it.
Frank
Old 17th Jan 2019, 8:19 am   #13
G4YVM David
Are the valves still obtainable?
David, G4YVM.
Old 17th Jan 2019, 8:44 am   #14
snowman_al
snowman_al's Avatar
Nuvistor is correct - That red one is a Junior. https://www.radiomuseum.org/r/roberts_junior.html
The aerial windings are in the groove under the white / cream strip.
There are plenty of valves for them out there.
To be honest they are pretty robust unless someone puts 90 volts across the filaments...
Most common problems are microphonic AF valves, but you can live with it.
More of a problem is the DK91 frequency changer going very slightly low. Then it only works with a full 1.5 volt supply. Fine if you use a battery eliminator, but not so good if you want a portable. Anyway they are easy to find if it needs replacement.
Alan
Old 17th Jan 2019, 10:33 am   #15
G4YVM David
Thank you all
David, G4YVM.
Old 17th Jan 2019, 10:50 am   #16
chriswood1900
If you can wait a couple of weeks there is the Auction at RWB on the 3rd Feb probably a good chance of something coming up just take a look when Mike/Paul posts the list.
Chris
chriswood1900 is offline
Old 17th Jan 2019, 11:04 am   #17
kalee20
No experience of one - but it looks like it ticks your all boxes.
Radios with this set of valves are capable of good performance! Having said that, SW on domestic sets was not particularly good, but is still fine with a strong signal.
kalee20 is online now
Old 17th Jan 2019, 11:14 am   #18
Alvin
Alvin's Avatar
The Junior radios in the posted ebay and radio museum links don't have SW which the OP said he wants but they do exist. In 2004 I purchased a MW & SW export version of the Junior from an ebay seller in the USA and sold it on a few years later - unfortunately I don't have a record of the model number and I no longer have the pics I took when I bunged it back on ebay.
Alvin is offline
Old 17th Jan 2019, 12:19 pm   #19
crackle
The Radio Museum has an error on this model page. It would seem from the circuit diagram that the Roberts Junior (the OP's radio of choice) is NOT line/battery (mains or battery)
So in order to use the red radio being auctioned on line, a 90 volt battery will have to be made.
I will propose a correction on the RM page.
Mike
crackle is offline
Old 17th Jan 2019, 2:26 pm   #20
G4YVM David
Thanks chaps. I might wait and look at the rwb list. Im in no rush.
D
David, G4YVM.
