15th Jan 2019, 5:33 pm | #1 |
Cheap valves on RS anyone tried them yet?
they have these:
RS Product Codes 678-4101 12AT7 ECC81 Double Triode, B9A base 678-4105 12AU7 ECC82 Double Triode, B9A base 678-4114 12AX7 ECC83 Double Triode, B9A base 678-4120 EL84 EL84 Output Pentode, B9A base 678-4108 6L6GC 6L6GC Beam Pentode, octal base 678-4117 EL34-B EL34 Output Pentode, octal base 678-4127 EL34-B-1 EL34 Output Pentode, octal base, matched pair set 678-4111 EL34-B EL34 Output Pentode, octal base, matched quad set 678-4123 KT88-98 KT88 Beam Tetrode, octal base 678-4136 KT88-98-1 KT88 Beam Tetrode, octal base, matched pair set 678-4139 KT88-98-2 KT88 Beam Tetrode, octal base, matched quad set The EL84 costs £9.76 including vat and postage, thats better than most second hand ones! They appear to be china imports (one of the photos of the ECC85 shows the word china on the valve) So anyone tried them yet? Derek |
15th Jan 2019, 5:34 pm | #2 |
Re: cheap valves on RS anyone tried them yet?
I have looked at them a few times but have not bought any yet..
15th Jan 2019, 5:51 pm | #3 |
Yes, I have bought and use very regularly 2 x EL84s from RS. They say "China EL84" on them. They run in my Bush SRG86 radiogram in single ended mode.
They sound undistinguishable to mullard ones to me. The radiogram is used nearly every day for many hours at a time, and has been for around 9 months now. It has a few times been on all night playing music. No issues at all yet, the EL84s would get my seal of approval I must add the SRG86 is a very good sounding radiogram, and is capable of pretty good fidelity |
15th Jan 2019, 6:04 pm | #4 |
I seem to recall reading that some Chinese valves can draw more anode current? Although KT66's are not specifically mentioned I wonder if this could be an issue in something like a Quad II where transformers are run close to the limit? Just a thought.
Howard |
15th Jan 2019, 9:12 pm | #5 |
Re: Cheap valves on RS anyone tried them yet?
It's certainly worth bearing in mind. I would expect anyone changing the valves in a Quad II to check the anode currents as a matter of course, though -- and adjust the cathode resistor if necessary.
If I had just bought a pair of Quad IIs (a gal can dream, right?) then I would give them a thorough going-over with my trusty multimeter anyway, since I would have no idea what the previous owner might have done with them! P.S. Was "ECC85" a typo, or is this possibly good news for owners of AM/FM sets?
15th Jan 2019, 9:43 pm | #6 |
I bought a couple of EL84s when rebuilding an MA12 (still to do its mate).
They provide the specified output in the amp and test to spec on Sussex tester - but have no yellow paint...
George |
15th Jan 2019, 10:13 pm | #7 |
I bought one of these valves from RS a couple of years ago - it was a 12AX7/ECC83. It was a replacement for one in the power supply of a Tektronix 549 scope. It worked absolutely fine. No complaints from me.
Chris
16th Jan 2019, 9:12 am | #8 | |
Then the heater broke. That's usually the very last thing to give in a valve so go figure. /Torben |
16th Jan 2019, 9:27 am | #9 |
16th Jan 2019, 9:46 am | #10 |
When purchased as an individual, Consumer Regulations 2015 applies.
16th Jan 2019, 10:02 am | #11 |
It's certainly not fair to draw any conclusion on the basis of a single sample having failed after two weeks IMHO.
16th Jan 2019, 10:12 am | #12 | |
I'm just saying that the picture isn't just rosy-red. The valve was pulled from my stock to repair the amplifier. It was delivered from RS more than a year ago so there's no hope of them replacing it for free. |
16th Jan 2019, 10:23 am | #13 |
Unless you bought it in the course of business, you have six years in which to bring a claim for an inherent fault. Whether it is worth the bother or not is a different argument.
16th Jan 2019, 10:49 am | #14 |
Yes they work. My Heath VTVM has one of the 12AU7's in it and has done for about a year now.
As for the returns from RS, they are really helpful and would replace that no questions asked. I have returned and replaced lots of stuff over the years with them and had no problems. There is a "failure bell curve" for any device that is put on the market. Some people are unlucky enough to get the early failures. It happens. |
16th Jan 2019, 11:22 am | #15 |
Isn't the "bathtub" curve more applicable here- relatively high infant mortality followed by relatively long period of low failure rate then rising again for wear out?
Even if these valves are not up to the standard of historical Mullards or the like, they may still be "fit for purpose" to keep old equipment running within specs.
16th Jan 2019, 11:44 am | #16 |
I've used several 6L6's in Jukebox amps and all have been to spec and lasted, some must be about 4 years older now. Have got some EL84's but have only subbed for a short time to check amplifiers working correctly.
16th Jan 2019, 12:00 pm | #17 |
I have found RS to be pretty good on returns.
I had peltier chip fail during a drink cooler experiment and they replaced it for me without any fuss. |
16th Jan 2019, 12:07 pm | #18 |
16th Jan 2019, 12:10 pm | #19 |
Pity they don't do ECC807s !
Paul Last edited by PaulR; 16th Jan 2019 at 12:17 pm. |
16th Jan 2019, 12:40 pm | #20 |
I've used RS's EL84 and ECC83 with no issues.
andydoz.blogspot.com |
