Old 18th Feb 2007, 10:38 pm   #1
Mike Brett
Default R1155 Loop
Hello all
Have just finished building a D/F Loop for the R1155. Can anyone who has done similar tell me what they used to connect the two together, in my case about one meter. I know it has to be twine screened cable so would RG58 be best or would a lighter audio screen cable do the job.
Many thanks Mike.
Mike Brett is offline
Old 18th Feb 2007, 11:37 pm   #2
John H.
Default Re: R1155 Loop
Hi Mike,
Have a loop myself - you need to use 2 wire twisted pair screened cable, not coax.
If you don`t have the correct`c` shaped Jones plug with its internal cap, you will require a small air spaced variable capacitor of 75 pf at the plug end across the loop pair to tune for mamimum sensitivity. John.
John H. is offline
Old 19th Feb 2007, 9:22 pm   #3
Mike Brett
Hi John
Many thanks for info, great help.
73s Mike.
