Old 2nd Oct 2018, 1:00 pm   #1
Steve G4WCS
Steve G4WCS's Avatar
Default Icom IC-251E
Ive just taken posession of one of the Radio's I used to eye enviously as a penniless teenager when I obtained my Amateur licence.
considering its age it appears to have been well looked after, and came in the original packaging.
Its also got the benefit of having the Mutek front end fitted, which subsitites the pin diode switching with a low noise raly and also has a superior mixer circuit to the Icom design.
powered it up off 12V last night and it was picking up at good strength on a bit of wire in the kitchen
https://www.youtube.com/watch?v=K3zsLEckBAg
As a base unit they came with a mains power supply. these were prone to failure.
It came with a spare, that someone has started a repair on. looking at the construction, whilst good from an RF screening persepctive, Im sure enclosing the active bits of the power supply in a small aluminium "roasting tin" didnt do it any favours, it does smell of baked electronic components.
Ill probably repair them long term, and look at introducing some cooling ( they didnt have miniauture 12V PC fans back in the day ) , but enjoy the radio as is for now
Ive also included a pic of my new scope, with many thanks to John_bs
ID:	170238   Click image for larger version
ID:	170239   Click image for larger version
ID:	170240   Click image for larger version
ID:	170241   Click image for larger version
Name:	psu compartment.jpg
Steve G4WCS is offline
Old 2nd Oct 2018, 1:01 pm   #2
Steve G4WCS
Default Re: Icom IC-251E
more pics
ID:	170243   Click image for larger version
ID:	170244   Click image for larger version
ID:	170245   Click image for larger version
ID:	170246   Click image for larger version
Old 2nd Oct 2018, 6:24 pm   #3
SiriusHardware
A Proper Radio, with one physical switch or control for every function. Well done finding it.
SiriusHardware is online now
Old 2nd Oct 2018, 10:13 pm   #4
g4aaw pete
g4aaw pete's Avatar
Hello Steve
I have one of those, also with the Mutek board.
I also have two of the 6m variants. None of the three have suffered power supply problems, but they are getting-on a bit now.
Good luck with the psu repair.
This is the diagram of the IC551 psu, which I believe to be the same.
Regards
Pete
g4aaw pete is offline
Old 2nd Oct 2018, 10:59 pm   #5
Steve G4WCS
Thanks Peter. IC1 looks “interesting” and unavailable . I wish you hadnt reminded me there was a 6M version to hunt down (last sunspot maximum was getting by with a PW MEON driven from an FT-757).
Old 2nd Oct 2018, 11:06 pm   #6
g4aaw pete
g4aaw pete's Avatar
Just noticed there are no values on the circuit diagram.
Old 2nd Oct 2018, 11:15 pm   #7
g4aaw pete
g4aaw pete's Avatar
There's also the 70cm variant.
But that's a step too far.
Old 3rd Oct 2018, 7:55 am   #8
Steve G4WCS
Thanks. of course I have a little black box that does all the bands but wheres the fun in that
Old 3rd Oct 2018, 2:10 pm   #9
buggies
buggies's Avatar
Been my main rig since new - never had any problems with it so only just opened the manual to look at the PSU. Quick mobile phone pics attached for comparison with 551 circuit.
ID:	170292   Click image for larger version
ID:	170293   Click image for larger version
George
buggies is offline
Old 12th Oct 2018, 10:55 am   #10
Steve G4WCS
spent a few hours on the case and panels.
It looks like a smoker has had it at some point.
the front panel and switches/knobs were very dusty and grubby.
Ive found that Cif bathroom foam works wonders for lifting dirt from hard surfaces, it does contain a small amount of ammonia, and Ive also got a tin of a wax polish type hard surface cleaner ( It was given to us when we got granite worktops ) works wonders also.
the Aluminium surround was quite oxidised, and has had a rub down with some 600 wet and dry wrapped around a pencil eraser to restore its brushed finish.
the rear panel idents still had the plastic film on from manufacture but was yellowed and lifting in places so this was carefully removed.
Name:	front view dirty.jpg
ID:	170745   Click image for larger version
ID:	170746   Click image for larger version
Name:	dirty and clean knob.jpg
ID:	170747   Click image for larger version
Name:	foam cleaner.jpg
ID:	170748   Click image for larger version
Name:	hard surface cleaner.jpg
Old 12th Oct 2018, 10:57 am   #11
Steve G4WCS
more pics
Name:	switches dirty.jpg
ID:	170750   Click image for larger version
Name:	switches clean.jpg
ID:	170751   Click image for larger version
Name:	side panel dirty.jpg
ID:	170752   Click image for larger version
Name:	side panel clean.jpg
ID:	170753   Click image for larger version
Name:	phonos dirty.jpg
Old 12th Oct 2018, 11:18 am   #12
Steve G4WCS
yet more pics
Name:	phonos clean.jpg
ID:	170759   Click image for larger version
Name:	ser no clean.jpg
ID:	170760   Click image for larger version
Name:	front panel clean 1.jpg
ID:	170761   Click image for larger version
Name:	front panel clean.jpg
Old 12th Oct 2018, 11:37 am   #13
Peter.N.
Makes me wish I still had my FT101ZD.
Peter
Peter.N. is offline
