Old 19th Nov 2018, 11:09 pm   #1
thevalveset
Default KW 160 low output... help please!
HI
My pal is restoring a KW 160 top-band transmitter which is suffering low output.
He tells me it is running about 11W DC input but only getting 3W output which seems a little inefficient. (According to Derby Radio club it should run 12W input for 8W out?)
He has asked me to scour the internet to find any service/alignment information to help with the repair but I have failed to find any.
Does anyone know if such information was ever published ie service sheet, alignment information or official handbook etc?
All information gratefully received.... thanks in anticipation.
Dave
thevalveset is offline
Old 20th Nov 2018, 12:05 am   #2
JohnBG8JMB
Default Re: KW 160 low output... help please!
hopefully, 2 files attached that should help
See also kw yahoo group
73
G8JMB
JohnBG8JMB is offline
Old 20th Nov 2018, 11:04 pm   #3
G3VKM_Roger
G3VKM_Roger's Avatar
Dave,
The KW-Radios group is here:-
https://groups.io/g/KW-Radios The Yahoo group John mentions has QSYed to groups.io
I have a KW-160 (and the ATU of the same name) if you need any measurements or info.
73
Roger/G3VKM
G3VKM_Roger is offline
Old 22nd Nov 2018, 4:18 pm   #4
James Duncan
Are you sure that the tube has not deteriorated, sounds like it could be
check that the correct HT is there to drive the tube.
James Duncan is offline
Old 22nd Nov 2018, 4:34 pm   #5
Nuvistor
Nuvistor's Avatar
What dummy load are you using, according to the files in post #2 the output is 75ohm and using a 50ohm will reduce the output, the doc suggests a work around.
Frank
Nuvistor is offline
Old 22nd Nov 2018, 5:26 pm   #6
HamishBoxer
HamishBoxer's Avatar
Check R30/R29/R17/R21 and also what the voltage is there.I notice a few caps I would check as well though guess they are not waxies?
HamishBoxer is offline
Old 22nd Nov 2018, 5:34 pm   #7
G3VKM_Roger
A query about the KW-160 that the OP and others may be able to help me with.
Recently, I had a couple of power problems with my transmitter which I took care of, but I then found that the PA meter reads a standing 20ma when key-up and on transmit. My 160 has the 21v PA heater line going to a single silicon diode and a 25uF cap to provide protective bias. I measure about -22V on the control grid of the PL81 PA, key-up. From comments made on the KW-Radios thread, I think others have seen this on their 160s, but I can't find any reference to a standing current in the info I have on the set. From the PL81 characteristics, it would seem that the standing current is normal for that bias voltage.
Does anyone else see this with their transmitter?
73
Roger/G3VKM
PS: I tried to post a better copy of the KW-160 cct but messed it up, so I deleted the post and will redo it.
Last edited by G3VKM_Roger; 22nd Nov 2018 at 5:40 pm. Reason: Attachment messed up.
Old 22nd Nov 2018, 5:39 pm   #8
G3VKM_Roger
This is a better cct IMO, than the SWM version.
73
Roger/G3VKM
Name:	KW_160 CCT with values.jpg
