Old 15th Nov 2018, 6:00 pm   #21
GW4FRX
GW4FRX's Avatar
Default Re: GEC BRT400 receiver.
Originally Posted by John KC0G View Post
Sadly the papers from the 1963 Convention are very hard to find. I know of only three copies in libraries in the U.K., and the British library does not appear to have one. The convention was organised by the Electronics Division of the I.E.E, and they published the papers as E.D. 4 (as shown on the spine), and not as a set of I.E.E conference proceedings which had recently been started. This was the first I.E.E convention on H.F. Communication since the Radiocommunication Convention in 1947 (J. I.E.E. Vol 94, 1947,part IIIA, Nos 11-16)
I have a copy of the E.D.4 convention papers if you need any references. Being interested in HF receiver design at the time I saved it when BBC Schedule Unit had a clear-out in about 1978.
GW4FRX is offline
Old 18th Nov 2018, 1:59 pm   #22
G8BBZ
G8BBZ's Avatar
Hi All,
The receiver referred to by Hawker is the Royal Navy Outfit CJA/CJC.
More info at:
http://www.commsmuseum.co.uk/receive...%20CJA/cja.htm
The receiver in the attached photo belongs to Don ZL4GX and shows the receiver with its associated Frequency Synthesiser.
Outfit CJC was a single receiver in a desktop cabinet without a synthesiser. Outfit CJA was a dual receiver installation with each receiver having an associated synthesiser in a floor mount cabinet and weighing nearly half a ton! The receiver alone weighs more than 150lbs. and is the only receiver I know which need air cooling - the cabinets have forced air circulation and there is an air intake port on the receiver to duct air to the IF amplifiers.
The synthesiser is not a true synthesiser in the modern sense. It compares a sample of the receiver local oscillator with an internally generated signal derived from an external 100kHz source to derive an error voltage. This is the fed back to the receiver to a reactance modulator on the local oscillator to correct any frequency error.
The Outfit CJA was intended primarily for the un-attended reception of RTTY broadcasdt traffic, and replaced Outfit CJK (Racal RA117E etc.) which had been introduced as a stop-gap due to the late delivery of CJA.
The extreme front end performance referenced by Hawker is achieved using selected ECC82 cascode RF amplifiers and 6 tuned circuits at signal frequency, housed in a massive turret.
Few of these receivers (and none of the synthesisers) seem to have survived in the UK, possibly because of the silver-plated chassis making the valuable as scrap.
If anybody has a synthesiser they don't want please let me know!
Peter G8BBZ
G8BBZ is offline
Old 18th Nov 2018, 2:34 pm   #23
International radiation symbol on the RX front panel at bottom right?
Radio Wrangler is offline
Old 18th Nov 2018, 3:35 pm   #24
CambridgeWorks
CambridgeWorks's Avatar
Another one on bottom left. I wonder if it is the gas reference or stabiliser tubes?
Rob
Apprehension creeping like a tube train up your spine - Cymbaline. Film More soundtrack - Pink Floyd
CambridgeWorks is online now
Old 18th Nov 2018, 3:52 pm   #25
G8BBZ
G8BBZ's Avatar
The receiver pictured is ex New Zealand Navy. My ex Royal Navy receiver doesn't have the radiation warning symbols. I think Robin may be right as there is nothing inside the receiver with any warning labels attached.
Peter G8BBZ
G8BBZ is offline
Old 22nd Nov 2018, 7:39 am   #26
John KC0G
Originally Posted by G8BBZ View Post
Hi All,
More info at:
Peter, thank you for this information. It is always interesting to know what can be done when you throw enough money and size at a problem.
The FRR-59A receiver and its shipboard counterpart the WRR-2A also used forced-air cooling. They were built by the National Radio Company in the 1960's. Most of the following information comes from Fed Osterman's book "Shortwave Receivers, Past and present, 1942-2013". The radio weighed 250lbs and split into two main pieces. It had 64 valves, and 24 semiconductors. it was envisioned as a replacement for the R390A. Apparently they were not particularly reliable.
You can find pictures at:
http://www.navy-radio.com/rcvrs/frr59.htm
If you look carefully you can see the air duct connection between the upper and lower parts.
A friend of mine has one which turned up a metal recycler. Quite literally the price was by the pound (weight).
73 John
John KC0G is offline
