Old 21st Jul 2017, 9:42 pm   #1
Ekcoman
Ekcoman's Avatar
Default Ekco Collaro arm set down issue
Can anyone point me in the direction as to where to locate the set down screw adjustment on this Collaro deck as starting into the record rather than the arm dropping down on the run in of a disc. Thanks
Name:	EKCO RP329.jpg
"I really am seriously downsizing "
Ekcoman is offline
Old 22nd Jul 2017, 9:20 am   #2
stumted2
Default Re: Ekco Collaro arm set down issue
If you lift up the turntable mat (you do not have to remove it) you will find a hole in the turntable.
Rotate the turntable until the hole is pretty much in line with the tone arm support, and using a torch, look through the hole in the turntable, and rotate the turntable slightly clockwise or anti clockwise until you locate the setting down screw which is located in the cam gear.
Adjust this (slightly) to adjust your setting down position. You will find there is a loose feel to the adjustment screw midway between adjusting it clockwise and anti clockwise, but this is quite normal.
Please let me know if I can be of any further help, cheers,
Ted.
stumted2 is offline
Old 22nd Jul 2017, 10:11 pm   #3
Ekcoman
Ekcoman's Avatar
Thanks Ted. Found it, adjusted and sorted and even found in my box of spares an original Collaro Cartridge to replace the BSRX5M replacement that had been fitted. The Collaro Cartridges seem to fair well over time and output is excellent.
This web site always comes up with someone who can help. This time it was Ted who came to my rescue.
Ok moderator you can now close this thread. Thanks
Ekcoman is offline
