Old 20th Jul 2017, 10:34 am   #1
camallison
camallison's Avatar
Default Cutting Veroboard
I have searched the various areas of the forum and I cannot find any definitive answer.
How do members cut Veroboard (or even PCB material) to the required size? What is your preferred method and how successful/clean is the cut?
Interested to hear about various methods.
Colin
camallison is offline
Old 20th Jul 2017, 10:43 am   #2
MrBungle
MrBungle's Avatar
Default Re: Cutting Veroboard
I use a metal ruler and a stanley knife. If it's veroboard, you score about half way through and it snaps neatly. If it's FR4 you have to give it a few cuts and then you can snap it. Comes up quite clean and you can finish it off with a file if you need to.
If I'm cutting pads out for manhattan construction, I'll cut strips off using the above method and then snip them up with some aviation shears when I need a length.
MrBungle is offline
Old 20th Jul 2017, 10:56 am   #3
John M0GLN
John M0GLN's Avatar
I also use a stanley knife and steel rule for straight lengths, for small pieces from a larger sheet it's a junior hacksaw, I cut through the holes and file flat, not really necessary but I still do it.
John
John M0GLN is offline
Old 20th Jul 2017, 11:39 am   #4
paulsherwin
paulsherwin's Avatar
Junior hacksaw here.
paulsherwin is offline
Old 20th Jul 2017, 12:13 pm   #5
camallison
camallison's Avatar
Thank you all. I currently use the knife and steel rule method but occasionally slip and wobble off the line.
Colin
Old 20th Jul 2017, 1:29 pm   #6
Bobdger
Bench shears, FR4, Vero and paxolin all cut clean. For a very good job I reset the blade gap to the required thickness setting.
Bob.
Bob, BVWS member
Bobdger is offline
Old 20th Jul 2017, 2:09 pm   #7
canonman75
No Longer a Member
For Veroboard I use nothing more than a junior hacksaw, then tidy up the rough edges with a small flat file.
canonman75 is offline
Old 20th Jul 2017, 9:43 pm   #8
ionburn
ionburn's Avatar
For Veroboard I score down the line of holes on both sides with a craft (or Stanley) knife then snap the board. A fairly light score is all that is generally needed. I then clean up all the edges with a smooth file, taking particular care to remove any flash on the ends of the copper tracks.
It gives a very tidy result.
For copper clad board I use a junior hacksaw, then finish with the smooth file.
ionburn is offline
Old 20th Jul 2017, 10:25 pm   #9
Craig Sawyers
Craig Sawyers's Avatar
Bandsaw. But only because one of my (too many) hobbies is amateur cabinet making.
Craig Sawyers is offline
Old 20th Jul 2017, 10:34 pm   #10
julie_m
I cut it through the holes and file away the excess, rather than risk undercutting by scoring and breaking it between tracks.
If I had a bandsaw, I'd most definitely use that; but it's hardly worth getting one just for cutting a piece of breadboard.
julie_m is offline
Old 20th Jul 2017, 11:06 pm   #11
Bazz4CQJ
Bazz4CQJ's Avatar
Piercing saw.
Bazz4CQJ is online now
Old 21st Jul 2017, 10:25 am   #12
Herald1360
Herald1360's Avatar
Boggo Veroboard or matrix board I just nick the end of the appropriate row of holes with side cutters and manually break along the row. With a bit of care you can break out rectangular pieces from a larger board without the need to cut right across.
FR4 style- hacksaw or Dremel.
Tidying up is optional- makes no difference to function!
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 21st Jul 2017, 10:32 am   #13
G6Tanuki
G6Tanuki's Avatar
I do the score-both-sides-along-the-holes-then-snap-it technique. For large pieces I like to clamp it in a vice with the score-line tight along the jaws before snapping it: that way you can apply more-uniform bending than when holding one side of the scoreline in each hand.
G6Tanuki is offline
Old 21st Jul 2017, 10:33 am   #14
wireless_john
wireless_john's Avatar
Hacksaw and file here. Can't bear to see the half holes round the edge. Always have to get the corners square too - don't know whether that's OCD or training when I was 16
GQRP Club 4704 - BVWS Member
wireless_john is offline
Old 21st Jul 2017, 10:58 am   #15
Ted Kendall
+1 here - and tidy up with deft use of side cutters or flat file.
Ted Kendall is offline
Old 21st Jul 2017, 11:29 am   #16
camallison
camallison's Avatar
Thank you all again. This weekend, I am going to try each method (except bench shear) on some scraps and see which one suits me best. My badly arthritic hands don't help!
Colin
Old 21st Jul 2017, 12:04 pm   #17
Skywave
Arrow Re: Cutting Veroboard
Veroboard: I use a vice, hacksaw and file.
FR4: as above, but I use a ruler plus a try-square first, plus fine ink-based marker pen.
Al.
Skywave is offline
Old 21st Jul 2017, 5:23 pm   #18
Andrew B
Andrew B's Avatar
I use a 5" 1mm thick metal cutting disc mounted in a grinder, a bit over the top, but I use the same method for cutting DS copper clad fibreglass board as we..
worried about the electrons entering the circuit and the smoke leaving
Andrew
Andrew B is offline
Old 21st Jul 2017, 5:37 pm   #19
Snip and snap for me with a clean up on the linisher (bench mount upside down belt sander).
Old 21st Jul 2017, 6:50 pm   #20
Andrew2
Andrew2's Avatar
Same as many above. For Vero and paxolin, deeply score it with a sharp Stanley and a steel rule and then snap it on an edge. Works best if I score both sides. For fibreglass types, a hack saw and file to clear up.
Andy G1HBE.
Andrew2 is offline
