14th Nov 2018, 3:40 pm | #1 |
Metal fence-post earth.
I recently had to replace some wooden fencing and while I was driving in one of the 20 or so galvanised metal supports (see attachment for photo - the wine bottle is included for size-reference) it occurred to me that the surface-area of a single support that was to be embedded in the ground was rather large - much greater than that of the traditional metal earth-rod used in conjunction with a typical MW/SW aerial.
The supports are now all coupled together using a length of 2.5mm single PVC-insulated wire, which is buried a couple of inches below ground to keep it out of reach of the strimmer. The house-end will connect to my Eddystone 840A 'bedside radio' in the hope of me getting some transatlantic MW DX later in the winter. --G6Tanuki "You can Rely on Pye". |
14th Nov 2018, 4:00 pm | #2 |
Re: Metal fence-post earth.
Nice bit of lateral thinking there, with dual-purposing and connection diversity. I'd always thought that the traditional rod must offer marginal contact area with the soil. I trust that the wine in the bottle didn't last long post- (!) completion....
14th Nov 2018, 4:02 pm | #3 |
Be aware of safety problems associated with introducing an alternative 'earth' into a domestic electrical system. The RSGB booklet on this basically advises "don't do it, but if you must, use a qualified electrician". It recommends using ungrounded antennas, such as dipoles. The details of the danger depend on how your house is wired.
14th Nov 2018, 4:03 pm | #4 |
Nice to see galvanised ones - all the "Metpost" ones I've used have been painted.
14th Nov 2018, 4:03 pm | #5 |
Yes, it seemed a shame to let such a good surface-area of buried metal just sit there supporting fenceposts when it could have a bit of RF flowing through it too.
[The remaining wine found its home in a chicken casserole] |
14th Nov 2018, 4:07 pm | #6 |
I'm assuming that the 840A is somewhat like the 670A here, with a mini patch-panel offering chassis and high voltage capacitor isolated signal earths.
None-the-less, a very worthwhile point to raise, and one deserving careful and thorough appreciation in any added "radio earth" situation. |
14th Nov 2018, 4:10 pm | #7 | |
14th Nov 2018, 6:16 pm | #8 | |
I think these galvanised ones (and the pressure-treated fenceposts which I've also drenched in creosote/old engine-oil) will still be OK when I'm consigned to the Bide-a-Wee Home for the Hopelessly Bewildered. Where I've connected the earth lead tags to the posts I've used a stainless-steel coach bolt through the metal into the wood, and slathered everything with semi-fluid moly-grease before tightening up so they should stay corrosion-free for a while. No "rusty-bolt" QRM-causing diode effects here! |
14th Nov 2018, 7:31 pm | #9 |
Red Oxide - great paint!
Red to red, black to black. Throw the switch and stand well back! |
14th Nov 2018, 10:16 pm | #10 |
Isn't it possible to isolate RF earths with a capacitor when it enters the building (if you have one of those PME systems)?
As for old engine oil as a preservative the oil is often acidic, so may not be the best presservative. T
Adapt, Improvise, Oh Bother..... |
14th Nov 2018, 10:21 pm | #11 |
But be sure to remember that the term "Red Oxide" now refers only to a shade of colour and has nothing to do with chemical composition (unless is it very old stock and still has lead in it).
The "Red Oxide Primer"sold at a very good price by Screwfix utilises zinc phosphate to inhibit corrosion. It has the "4CQJ" 5 Star seal of approval. It is actually made by the Johnstone's Company but packaged in small tins for Screwfix. (no connection with either company) B
15th Nov 2018, 3:37 am | #12 |
The other thing to be aware of is that the galvanising on the post can/may react with acid in the soil because of the current (however small it may be) passing through it and cause all sorts of strange symptoms.
Probably not in the short term, but definitely in the long term (rust/corrosion makes a good parasitic semiconductor). The copper wire joining the posts may also react depending on how you connected it to the posts. |
15th Nov 2018, 5:52 am | #13 |
Zinc (plating)
Mild steel Stainless steel Copper wire A tiny bit of rust somewhere Used engine oil (could be acid or base, and with numerous additives) Creosote Soil “No "rusty-bolt" QRM-causing diode effects here!” B
