12th Nov 2018, 10:27 am | #1 |
RCA AR88 Receiver. R.1967 variant.
Hello.
Came home from Golborne swop meet with a RCA AR88. On the front is a tag saying:- Receiver type R.1967 Ref -nu IOD/18430 A^M serial no ATB 1062 Modified by B.T.R. LTD It has all the tools that came with it when new and the Bristol wrench for the grub screws for the knobs on the the front panel. I have a AR88 LF that was modified by C.G.N. in the workshop. Kevin. |
12th Nov 2018, 10:42 am | #2 |
Re: RCA AR88 Receiver.
Kevin,
Any chance of a close-up picture of the AM label, please? Many thanks, Andy |
12th Nov 2018, 11:08 am | #3 |
Looks to have a non-original output transformer.
The front panel has extra holes in the headphone area, but one bunged-off, so I think it's seen two rounds of mods. David
12th Nov 2018, 11:17 am | #4 |
This seems to be a post-war use of it.
If you want to know more then Air Publication 2566D seems to be where to look. It is possible that one change was to have a higher impedance output than normal, so this fits with a changed output transformer and extra sockets. |
12th Nov 2018, 11:20 am | #5 |
Nice one- always good to have a thermionic project as winter draws in! Looks pretty good inside and out- not to mention the bonus of included trim tools.
I was reminded of a previous thread (also from Kevin) by that output transformer, the transformer looks to be of good quality, perhaps a UK military contract to replace the RCA original? https://www.vintage-radio.net/forum/...d.php?t=138320 |
12th Nov 2018, 11:45 am | #6 |
If it's any use the under chassis layout and schematic for the R1967 are shown on the two pages of AP 2566D that are included at the end of the link shown below (scroll down to the end):
https://www.blunham.com/Radar/Signal...68andR1475.pdf Lawrence. |
12th Nov 2018, 11:57 am | #7 |
Lawrence
The link you you have put on will not work . Thanks for helping. Kevin. |
12th Nov 2018, 11:59 am | #8 |
12th Nov 2018, 12:03 pm | #9 |
Lawrence its working know, Thank you.
Kevin. |
12th Nov 2018, 12:19 pm | #10 |
Andy.
Photo of A/M Label. Kevin. |
12th Nov 2018, 5:17 pm | #11 |
Kevin, many thanks!
Andy |
12th Nov 2018, 7:39 pm | #12 |
You are welcome Andy.
Regards Kevin |
13th Nov 2018, 11:11 am | #13 |
Slightly curious that the aerial trimmer shaft coupler is a solid (patina'd brass?) item- normally this is a sprung isolating coupler that allows for a smidgeon of front support bracket/chassis misalignment without being too hard on the bearing plus a bit of fore-and-aft movement inevitable with handling by the unappreciative. It's always possible that there were changes in component availability over the production life, though.
13th Nov 2018, 12:27 pm | #14 |
The couplers on both my AR88s are solid, too. It uses the bushing in the capacitor and that in the chassis bracket to stabilise the whole knob and shaft assembly from rocking.
13th Nov 2018, 12:37 pm | #15 |
Looks like the grafting points for the S meter are different to the original AR88.
Lawrence. |
13th Nov 2018, 4:00 pm | #16 |
That's usually the first query with a lot of people ie has it got an original meter-circa 1942 [I think] but these are apparently very rare now and given this is a 1967 retro fit, I suppose that would be unlikely. I'd never heard any mention of these post war modified versions before anywhere but they would have been both readily available and of such very high quality that it would make sense. Both sets look very similar but only one has the blanking plate and a sixties date. Did you get any further info re the background history on either at the point of purchase Kevin?
Dave W Last edited by dave walsh; 13th Nov 2018 at 4:15 pm. |
14th Nov 2018, 3:28 pm | #17 |
Dave.
No I did not get any background history on the 2 two sets. They are 88LF sets and the RAF and RN would put two 88LF linked to each other to make a Dual Diversity receiving outfit for shore wireless stations. On the web it says That CGN did a Technical hand book on the dual diversity unit for installation specification and repairs. I have been looking for this manual for a long time. Kevin. |
14th Nov 2018, 5:43 pm | #18 | |
Anyway for the record, my mid-range serial number set with its springy isolator, Colin |
