8th Nov 2018, 11:07 pm | #1 |
Unidentified vintage components
These components were in a box of vintage resistors. I don't know what they are and where they were used. Can anyone identify these please.
8th Nov 2018, 11:13 pm | #2 |
Re: Unidentified vintage components
Insulated stand offs and feed through ? used before tag strips the bush TR82 uses plastic items very similar.
John. |
8th Nov 2018, 11:17 pm | #3 |
I have a couple of the bottom item, which is a feedthrough for bringing out a connection through a metal barrier or the wall of a metal box. It would be soldered in place. I don't recognise the other two.
8th Nov 2018, 11:24 pm | #4 |
The top one is a simple stand-off tag connector - a single version of a tagstrip if you like. The spacer will be ceramic. The middle one looks very strange!
Andy G1HBE. |
8th Nov 2018, 11:24 pm | #5 |
Thanks gentlemen. That does make sense. First I thought they were old diodes but they are showing continuity on my meter apart from the ceramic glass 'waist' area.
8th Nov 2018, 11:55 pm | #6 |
I also have some of these.
The lower item is probably made by KLG (of spark plug fame) and widely used in oil-filled transformers (Parmeko etc) where they are soldered into the sealed can to form the terminals. The middle one is of similar application but made of glass. |
9th Nov 2018, 12:13 am | #7 |
Feed through capacitors?
worried about the electrons entering the circuit and the smoke leaving Andrew |
9th Nov 2018, 12:48 am | #8 |
9th Nov 2018, 4:29 am | #9 |
Insulated feed thru's.
They also made feed thru capacitors that could look very close. Come to think of it, an insulated feed thru would have a certain amount of capacitance. |
9th Nov 2018, 9:32 am | #10 |
Agreed, except to add that it will be a feed-through capacitor, almost certainly of 1000pF (0.001uF).
10th Nov 2018, 6:26 pm | #11 |
I seem to recall that the feed-through capacitors have a silver, or silvery, covering over the outside outer surface of the ceramic tube.
If so, as ukcol says, almost certainly 1000 P.F.. Tony |
