27th Oct 2017, 11:47 am | #81 |
Re: Triang Children's Record Player
For the mounting, a variation on this:
http://www.vintage-radio.net/forum/s...d.php?t=140523 ought to work. Graham
Half my stuff is junk - trouble is, I don't know which half! |
27th Oct 2017, 1:58 pm | #82 |
If you prefer to glue it you could always use hot-melt glue if you have a suitable glue gun. It's strong enough but can be removed at a later date and won't do any harm.
Anyway, you're a little way away from this so let's get it going first! Invest in a PP9 battery and get ready to wire the amplifier up. Did you get any capacitors? If not let us know the values printed on them (the white tubular jobs) - I see a 50uF one. They will have a value (such as the 50uF mentioned) and a voltage - possibly 12v. Let us know what they are and I'm sure one of us will have some - very much smaller, but that's progress! Easier to replace them while it's in bits. Let us know where you've got to. Glyn |
27th Oct 2017, 4:16 pm | #83 |
I do indeed have a glue gun, so should work. I also have a ton of 9V/PP9 batteries so that shouldn't be a problem. Here's the uF and voltages from the white capacitors:
50 uF 12VDC 10uF 6VDC Those appear to be the only two differen't ones. Progress wise, the only thing I've done is test the turntable which does indeed work. |
27th Oct 2017, 8:46 pm | #84 |
I have used a few of those red and black cartridges and they sound very good, I use hot glue to secure them in place , I find its strong enough for normal use yet can be easily peeled off if needed.
29th Oct 2017, 3:13 pm | #85 |
Please note this delayed post.
31st Oct 2017, 8:28 am | #86 |
Sorry, didn't see this post. If possible some photos showing the wiring would be nice, and yes I'm still working on it.
31st Oct 2017, 12:29 pm | #87 |
In post #2 you were given a link to another thread for information on your player.
In post #10 I advised you to read through the thread linked to in post #2. The thread linked to would have answered just about all the questions you have subsequently been asking. You have either inadvertently or deliberately ignored that particular piece of advice! |
1st Nov 2017, 1:38 pm | #88 |
Sorry. I have seen the reply, but haven't read through it yet. I will do.
4th Nov 2017, 11:57 am | #89 |
I've attached some pics o help you re-assemble - hope these are of use to you
4th Nov 2017, 11:59 am | #90 |
Five further pics attached ...
4th Nov 2017, 12:01 pm | #91 |
one further pic showing the volume control pot wiring ...
4th Nov 2017, 5:05 pm | #92 |
Thanks very much!
14th Nov 2017, 12:30 pm | #93 |
Just a quick update: I have ordered the new cartridge, been about a week but still hasn't arrived. Will post once it has.
30th Nov 2017, 7:59 pm | #94 |
Still hasn't arrived. No clue why. Will re-order it and hope for the best.
1st Dec 2017, 9:17 pm | #95 |
It's probably on the proverbial "slow boat from China"
10th Jan 2018, 1:58 pm | #96 |
Finally the new stylus arrived! What should I go about doing now?
10th Jan 2018, 2:42 pm | #97 |
You say that a new Stylus has just arrived, but in an earlier Post you said you had ordered a cartridge - which is it?
Edward. |
10th Jan 2018, 5:45 pm | #98 |
10th Jan 2018, 6:52 pm | #99 |
Now you have a new cartridge you should test to see if the amplifier/speaker are working. If you gently touch the cartridge you should hear a "rustling" noise in the speaker. If nothing, then the amplifier will need to be checked next.
Edward. |
10th Jan 2018, 7:23 pm | #100 |
But nothing is wired up, so would I need to connect the speaker to the mainboard or whatever it is before I can do that?
