14th May 2016, 9:10 pm | #121 |
Re: Dansette Conquest auto mk2 (Actually a mk1).
can you measure with the unit switched on ,
the voltage from the chassis to tags 2 and 5 of the output transformer. |
14th May 2016, 9:11 pm | #122 |
0.6ohms for yellow and open circuit for brown wire. i hope that right!
14th May 2016, 9:19 pm | #123 |
See above post 121
14th May 2016, 9:25 pm | #124 |
i hope i did it right photo attached
14th May 2016, 9:36 pm | #125 |
Yes that is fine thanks
Can you get a piece of wire and connect the bottom left hand speaker tag to the right hand transformer tag, whilst playing a record. |
14th May 2016, 9:39 pm | #126 |
not a problem peter. i take it its the output transformer and connect to the red wire tag
14th May 2016, 9:47 pm | #127 |
Does the brown wire from the right hand transformer tag already go to the bottom left hand speaker tag (also brown wire)?
14th May 2016, 9:52 pm | #128 |
the brown wire from the speaker goes to the pcb and the brown wire from the transformer also goes straight to the pcb.
do you still want me to connect the wire up? |
14th May 2016, 9:54 pm | #129 |
To the same place on the PCB? IE are they connected?
14th May 2016, 9:59 pm | #130 |
heres a picture of it as they say it paints a thousand words. they are not connected
14th May 2016, 10:03 pm | #131 |
should i still go ahead connecting the spare wire and play a record?
14th May 2016, 10:08 pm | #132 |
Well find out where that left hand wire goes because one speaker should connect across the 2 outside tags of the output transformer we can see that the left hand tag does but those 2 wires I feel should be joined. perhaps they both go to chassis via some print.
14th May 2016, 10:14 pm | #133 |
I'm off To bed now can someone else help a while?
14th May 2016, 10:14 pm | #134 |
the wire connects underneath the pcb. ignore the holes in the solder, they have been corrected.
14th May 2016, 10:14 pm | #135 |
ignore the rectifier wire too that has been corrected too.
14th May 2016, 10:17 pm | #136 |
okay peter thanks for your patience and time....maybe we will get sorted another time
14th May 2016, 10:22 pm | #137 |
This is such a simple circuit and yet you are still struggling, so why don't you get some help from this Forum as there are a number of Members up there in the North East? You are now on your 7th page and it's been going on far too long! Edward
14th May 2016, 10:40 pm | #138 |
That brown wire referenced in post #134 must be connected to something. It looks like it's connected to the resistor immediately to its right in post #130. If so, where does the other end of the resistor connect to?
14th May 2016, 10:43 pm | #139 |
yeh your right ed....just carried on from peters thinking and got her up and running...thank you all for your patience and help over today.
its working excellent....full volume. again thank you to you all |
14th May 2016, 10:45 pm | #140 |
graham the brown wire from the left hand speaker was connected to the pcb but should of been connected to tag1 on the output transformer.
