22nd Apr 2016, 9:18 pm | #41 |
Re: Dynatron Henley RG33W radiogram
If you replaced the fuse,did it blow again?
22nd Apr 2016, 9:20 pm | #42 |
No, the fuse is fine (and the bulb over the record player still operates with the piano keys).
22nd Apr 2016, 9:23 pm | #43 |
So you have continuity all the way through the power lead, on/off switch and transformer primary? Then the next thing to test would be the secondary side of the transformer.
With the set switched off, connect your meter, set to 20 V AC ~, to pins 4 and 5 of any valve (count clockwise from the gap, because you are looking at the underside, but it will be obvious anyway; there will be two fairly hefty twisted wires, linking pins 4 and 5 of all the valves to each other), preferrably using crocodile clip adaptors so you can keep your hands well clear. Then switch the set on. What voltage reading do you get? (Anything between 5.67 and 6.93 is good.)
22nd Apr 2016, 9:27 pm | #44 |
22nd Apr 2016, 9:47 pm | #45 | |
Same result with bulb removed |
22nd Apr 2016, 9:51 pm | #46 |
...which is good, as it means that the primary of the transformer really is OK.
23rd Apr 2016, 10:22 am | #47 | |
23rd Apr 2016, 10:29 am | #48 |
Trace the wires from pins 4 and 5 of the valves back towards the mains transformer. Then check the voltage directly on the transformer.
23rd Apr 2016, 11:20 am | #49 | |
23rd Apr 2016, 11:22 am | #50 | |
23rd Apr 2016, 11:57 am | #51 |
So, we think power is going into the transformer; but it isn't coming out the other side. Can you get some good, clear pictures of the transformer and the wiring immediately connected to it?
23rd Apr 2016, 2:31 pm | #52 | |
23rd Apr 2016, 5:32 pm | #53 | |
Which one do I need to check the voltage of? The large one seems to have some substance coming out underneath... |
23rd Apr 2016, 6:33 pm | #54 |
Vintage 84, apologies if i
I'm stating the obvious, but your meter should be set to a low ac voltage range, when checking the heaters(pins 4 & 5) 'E' series valves, such as those in your Dynatron, are run from nominally 6.3vAC. |
23rd Apr 2016, 6:43 pm | #55 |
I was just using the auto AC setting on my multimeter as it doesn't allow voltage to be set. I haven't used this in a few years so let me know if that's not what I was supposed to be using!!
23rd Apr 2016, 6:53 pm | #56 |
The smaller transformers are the output transformers. The other one is the mains transformer.
23rd Apr 2016, 7:07 pm | #57 | |
With the unit unplugged from the mains supply try and trace the wires from pins 4 & 5 of the valves back to that transformer, those will be the heater supply, in some radios etc there are two wires one from pin 4 and one from pin 5 running back directly to the transformer, in others only one wire from either pin 4 or 5, if it's the latter case then one of the valve socket heater tags will be connected to the chassis as will one of the heater supply tags at the transformer. Once you've identified the correct tags on the transformer you can apply power and do the heater voltage measurement but do it reasonably quickly as that transformer might have been a bit stressed by a fault judging by the wax on it. AC Auto range will be ok for measurements with your meter. EDIT: Woops, my post crossed. Lawrence. |
23rd Apr 2016, 7:45 pm | #58 |
I've traced these cables back to the main transformer and I'm not getting any output reading from the multimeter
23rd Apr 2016, 8:08 pm | #59 |
So presumably a new transformer is required as the input into the transformer is fine, but there is no output.
23rd Apr 2016, 8:34 pm | #60 |
One possibility is that there's a short circuit across the heater supply line. Remove the valves and measure the resistance looking into the transformer.
