Old 22nd Jan 2014, 11:31 pm   #181
kevinski
Default Re: Pye Black Box
Which is the reserve capacitor? Is that the big can? Also how would you measure the capacitor?
Kevin
kevinski is offline
Old 23rd Jan 2014, 10:48 am   #182
Station X
Station X's Avatar
The reservoir and smoothing capacitors are housed within the can. Measure the DC voltage between chassis and each tag of the can. If the can is grounded by a tag, expect this tag to read 0V.
Graham. Forum Moderator
Station X is offline
Old 23rd Jan 2014, 2:35 pm   #183
kevinski
Getting only 1Vdc on all three tags when measuring black lead from meter to chassis and red lead to each tag in turn
Kevin
kevinski is offline
Old 23rd Jan 2014, 2:49 pm   #184
Station X
Station X's Avatar
Which version of the Black Box do you have Kevin? I can't seem to find a version with a diagram like that in post #173.
Could be a rectifier problem. Assuming it's a thermionic type, Is it lit? Are any valves lit?
Old 23rd Jan 2014, 3:15 pm   #185
kevinski
Just checked my rectifier which I changed to a modern one with a 220Ω 7w resistor and I'm only getting 50Vdc from it (now gone up to 89Vdc?). The type of black box is BB/A according to the radio museum
http://www.radiomuseum.org/r/pye_black_box_bba.html.
The rectifier is a metal rectifier not a thermionic rectifier. All the valves are lit the way you would expect.
Kevin
kevinski is offline
Old 23rd Jan 2014, 4:57 pm   #186
Station X
Station X's Avatar
Unfortunately I don't have the circuit fro the BBA version. Perhaps you or another forum member could post the Power Supply part of the circuit here?
I would suggest the first thing to do is check the 220R resistor to make sure it hasn't gone high resistance. This is very unlikely if it's a wire wound type..
If that's OK, disconnect the rectifier from the mains transformer and measure the AC voltage on the secondary winding or windings feeding the rectifier.
Old 23rd Jan 2014, 5:11 pm   #187
Station X
Station X's Avatar
Here's an extract.
The smoothing and reservoir caps are on anther part of the diagram in a classic C-R-C arrangement.
Old 23rd Jan 2014, 6:58 pm   #188
Herald1360
Herald1360's Avatar
Explicitly (with non PSU bits removed) see attached:
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is online now
Old 23rd Jan 2014, 11:13 pm   #189
Michael Maurice
Michael Maurice's Avatar
In both Graham's and Chis's diagrams, MR1 has according to you been replaced by a modern silicon rectifier with a 220R resistor connected in series with one leg from the mains transformer.
Measure the resistance of that resistor it should read 220R if this is OK then next switch your meter to AC range and measure the voltage accross the ~ terminals of the rectifier. You should get around 250V AC.
Let us know what the results are.
Forum Moderator
Michael Maurice is offline
Old 24th Jan 2014, 6:15 pm   #190
kevinski
The resistor still reads 220Ω but I'm not getting any volts across the rectifier. With the resistor removed I measured the blue wire and the black wire separately with the black lead from the meter attached to the neutral tag on the mains switch I get 10Vac on the blue and 206Vac on the black.
Kevin
kevinski is offline
Old 24th Jan 2014, 6:32 pm   #191
Radio_Dave
Radio_Dave's Avatar
Hi Kevin,
With the mains disconnected measure the resistance between the body of the smoothing capacitor and the chassis, it should be zero. I've had problems with two of my black boxes because this capacitor had a poor connection to the chassis.
I think it also might be useful if you posted some pictures of how you swapped out the original rectifier and added the series resistor.
Radio_Dave is offline
Old 24th Jan 2014, 11:38 pm   #192
Station X
Station X's Avatar
There is no physical connection between mains neutral and the rectifier.
You need to measure the voltage between the two AC tags on the bridge rectifier. These may be marked ~ .
Old 25th Jan 2014, 12:14 am   #193
kevinski
Station X.
kevinski is offline
Old 25th Jan 2014, 1:07 am   #194
Station X
Station X's Avatar
That isn't consistent with post #185 where you say you're getting 50V to 89V. I assume that's on the DC side of the rectifier?
If it's on the DC side of the rectifier you should get the same voltage across the reservoir capacitor, as these points are wired together.
Old 25th Jan 2014, 10:45 am   #195
kevinski
Radio Dave - Picture of how rectifier + resistor has been fitted.
Station X - The inconsistency of measurements is THE main problem with this project. One time it measures ok next it's something completely different.
Kevin
Name:	Rectifier + Resistor.jpg
kevinski is offline
Old 25th Jan 2014, 11:50 am   #196
Station X
Station X's Avatar
Looks like the resistor has been wired in on the AC side of the rectifier.
What AC voltage do you get on the Blue and Black wires at the transformer? ie with one meter lead connected to each transformer tag.
What AC voltage do you get with one meter lead connected to each side of the resistor?
Finally what's the AC voltage with one lead connected to the rectifier end of the resistor and the other to the diagonally opposite tag on the rectifier?
Old 25th Jan 2014, 11:58 am   #197
Radio_Dave
Radio_Dave's Avatar
Kevin, You were advised to change that rectifier in post #15. Did you never change it?
Old 25th Jan 2014, 12:10 pm   #198
Station X
Station X's Avatar
According to post #158 a new rectifier was tried. The one in the picture doesn't look new to me though. Taking a few voltage measurements will do no harm.
Old 25th Jan 2014, 12:15 pm   #199
kevinski
Radio Dave - Yes I did change it using this
http://cpc.farnell.com/jsp/search/pr...sp?SKU=SC11465
Station X - I get 0Vac when I measure at any of those locations
Kevin
kevinski is offline
Old 25th Jan 2014, 12:18 pm   #200
kevinski
Station X - the one in the picture is new but has been put into the original metal block and sealed using Epoxy putty (as recommended by Michael in an earlier post)
kevinski is offline
