Old 10th Dec 2020, 4:47 pm   #1
McMurdo
McMurdo's Avatar
Default Kenwood A701A food mixer bowl.
I've inherited an A701A (light blue) mixer with the glass bowl.
The problem I have is that as it's mixing, the planetary action 'undoes' the bowl and it comes free. The bayonet action seems to be designed that way.
When I've looked in the trade spares catalogue, the bayonet recess on the new bowl seems to go the other way, IE the planetary action tends to tighten, rather than release the bowl.
Is this a production mod, or have I just got the wrong bowl?
Kevin
McMurdo is offline
Old 10th Dec 2020, 7:02 pm   #2
barrymagrec
Default Re: Kenwood A701A bowl
Sounds like you have the wrong bowl - ours drops into place and tightens clockwise.
Australian version?
barrymagrec is offline
Old 10th Dec 2020, 9:16 pm   #3
FIXITNOW
FIXITNOW's Avatar
my A901 (same white bowl) also tightens clockwise
FIXITNOW is online now
Old 10th Dec 2020, 9:26 pm   #4
audiomm
Are the lugs on the glass bowl intact as broken ones will not 'lock' properly. Another thing to check is the the base where the bowl fits in. There is an aluminium disc which sits on a rubber (or plastic)) pad and the overall thickness is critical to make the bowl lock properly. Take both out and check. You'll likely find them stuck in place due to spills etc over the years, but they can be removed with a bit of patience & brute force
Oh, also check that the K Beater, Whisk or Dough hook are NOT touching the bowl at all. If they are then adjust them to clear - see attached.
And finally ensure the feet are in good condition - there should be an air gap between the mixer base and your benchtop. This is essential for air cooling of the motor. If the feet have flattened and the mixer sits hard down on the bench then expect the motor to overheat and eventually fail.
I hope this helps. Mike
audiomm is offline
Old 10th Dec 2020, 9:34 pm   #5
trsomian
The way the beater fits in on ours will confirm (or deny) that the beater is revolving the correct way - its on an slight sort of scroll so that it only locks one way. Assuming it is correct, then don't forget the height of the K beater is adjustable and a slight adjustment there may have the desired effect. I agree with the earlier responses though, the bowl needs to lock in on the tapers, not simply sit.
trsomian is offline
Old 11th Dec 2020, 6:26 pm   #6
McMurdo
McMurdo's Avatar
The bowl tightens clockwise, viewed from above, and the mixer goes anticlockwise, hence why it seems to be loosening it. The bowl mat has long gone and I made a new one out of foam to sit under the aluminium disc.
When I'm looking on the connect website their replacement kenlite bowl tightens anticlockwise, though of course the pic may be reversed!
I know my mums late 70's chef goes on clockwise but I cant remember which way the beater goes.
I replaced the shaft on the k-beater some time ago so that's set up as per the service manual.
I want to use the dough hook for making bread but it soon has the bowl off and wobbling all about.
Kevin
McMurdo is offline
Old 12th Dec 2020, 12:12 am   #7
Refugee
Refugee's Avatar
Have a look under the motor cover and make sure it has not been "got at" following a capacitor problem.
Refugee is online now
Old 12th Dec 2020, 10:00 am   #8
duncanlowe
Looking at videos online, the rotation does appear to be anticlockwise, with the beater going clockwise as it goes.
duncanlowe is offline
Old 12th Dec 2020, 10:42 am   #9
fetteler
fetteler's Avatar
I have just had our 701A out and checked - when viewed from above the bowl locks clockwise and the beaters revolve anticlockwise and yes it is in the direction that friction would undo the bowl but that's never happened even with bread dough in there.
Perhaps you need to adjust the foam under the mat for a nice snug fit?
Steve.
Those who lack imagination cannot imagine what is lacking...
fetteler is offline
Old 14th Dec 2020, 12:20 pm   #10
Lancs Lad
Lancs Lad's Avatar
Default Re: Kenwood A701A food mixer bowl.
Sounds to me like the rubber mat might be crucial for the mixer to work properly.
It must provide some sort of gripping action to stop the bowl turning. It would be impossible for a foam mat to give any grip at all, surely?
Just a thought - hope it helps
Best Regards,
Peter.
Lancs Lad is offline
Old 14th Dec 2020, 12:34 pm   #11
Uncle Bulgaria
Uncle Bulgaria's Avatar
I'd check the mat as well. New ones are available and when I repaired my grandmother's A701A all was fine.
I'd second audiomm's point about the adjustment of the beaters too. This is crucial, though do check whether there are specific instructions for the A701A in case it differs from the A701.
Uncle Bulgaria is offline
Old 14th Dec 2020, 2:31 pm   #12
g8jzyian
Hi
I have just checked our 701 and from above the bowl locks clockwise the planetary action runs anticlockwise but the outer edge of the beater runs clockwise next to the bowl. There is a rubber mat under the bowl.
I keep a close eye on the wear on the rubber feet and have a set in the drawer for when they wear down.
g8jzyian is online now
Old 14th Dec 2020, 10:17 pm   #13
McMurdo
McMurdo's Avatar
Well, someone's certainly been in the motor (me!). I changed the filter and motor capacitor and reterminated the chafed mains flex. After looking at a picture of the (missing) bowl mat, I fashioned one out of a sheet of rubber. thicker than the one I made from foam. It's certainly tighter! I just don't ever remember one on my mother's chef, although that had the Kenlite bowl.
Kevin
McMurdo is offline
Old 14th Dec 2020, 11:12 pm   #14
mark_in_manc
Mike
Hey, thanks Mike Ours fell off the worktop (don't ask) and I had to do radical surgery with internal plates to hold it all back together, and now the beater just about hits the bowl. I never realised one could screw the thing up and down. Result!
"The best dBs, come in 3s" - Woody Brown
mark_in_manc is offline
Old 14th Dec 2020, 11:21 pm   #15
McMurdo
McMurdo's Avatar
The correct height adjustments for the various attachments are in the service manual manual if anyone wants a copy.
Kevin
McMurdo is offline
Old 14th Dec 2020, 11:58 pm   #16
mark_in_manc
I didn't measure the thread pitch, but I went in 1/2 a turn at a time until it stopped going 'clonk'. Is the manual you have, the service manual? (ah, edit - yes it is, you said as much!). That could be handy - not done the motor on my one yet. I've only had it for 20 years and it was older than that when I bought it!
Old 15th Dec 2020, 2:04 am   #17
McMurdo
McMurdo's Avatar
The height instructions are different to those in the owner's manual
Kevin
McMurdo is offline
