Old 14th Oct 2018, 10:06 pm   #1
CesarLG
CesarLG's Avatar
Default BV-613 receiver
Hello!
I would like to have some information on this green radio. A circuit diagram would be great. I would love also an actual picture in order to understand if what I have have is original or some parts have been taken out.
Here you have some pictures
ID:	170945   Click image for larger version
ID:	170946   Click image for larger version
ID:	170947   Click image for larger version
ID:	170948   Click image for larger version
CesarLG is offline
Old 15th Oct 2018, 9:22 am   #2
M0FYA Andy
Default Re: BV-613 receiver
I recollect that this radio is covered in the Wireless For The Warrior series of books.
Andy
M0FYA Andy is offline
Old 15th Oct 2018, 9:40 am   #3
Station X
Station X's Avatar
It's covered in volume 3 of WFTW. No circuit diagram though.
Built by Philco in 1944. Your set looks complete when compared with the drawings.
It's derived from Reception Set BV-611 and BV-612 (1942) for which there is a circuit in WFTW.
Graham. Forum Moderator
Station X is online now
Old 15th Oct 2018, 10:24 am   #4
CesarLG
CesarLG's Avatar
Well it is good that ig is from 500 to 1500kHz... So i can receive commercial radio at least. I saw information that stated it to be 200-500kHz
What I need to know is more or less is condenser values...
I hope the vibrator is working
CesarLG is offline
Old 15th Oct 2018, 11:58 am   #5
Station X
Station X's Avatar
I lack a flat bed scanner, so can't scan the 612 circuit for you.
If you can wait a day or two I'll photograph it for you. I photograph things outside where the light's good, but it's raining at present.
Old 15th Oct 2018, 12:00 pm   #6
CesarLG
CesarLG's Avatar
Thank you very much! I guess it is similar than the 612
CesarLG is offline
Old 21st Oct 2018, 1:55 pm   #7
Station X
Station X's Avatar
I've taken the pictures. PM me your email address and I'll send them to you.
Old 22nd Oct 2018, 1:42 pm   #8
Station X
Station X's Avatar
Pictures sent. The files are large as I did not want to reduce them and lose detail.
Old 25th Oct 2018, 7:24 am   #9
CesarLG
CesarLG's Avatar
I just received the radio. It is complete but the vibrator is not working. I have checked connections on the 2 sides of the relays, and they are fine. I have cleaned them with contact cleaner and used a very thin file to eliminate any rust. Still nothing. I have also applied 6V directly to the vibrator on the table, still nothing.
I am thinking about using a solid state one. Has anybody tried this?
ID:	171505   Click image for larger version
ID:	171506   Click image for larger version
ID:	171507   Click image for larger version
ID:	171508   Click image for larger version
EA3IAV
CesarLG is offline
Old 25th Oct 2018, 8:36 am   #10
Station X
Station X's Avatar
That doesn't look too bad when compared to some old vibrators I've seen. If the coil has continuity, the contacts are clean and the armature is free to move there's no reason why it shouldn't work. Can you measure the coil's resistance between pins 1 and 2? Ditto pins 1 and 4?
I've used a solid state vibrator SSV and it works fine.
Old 30th Oct 2018, 8:45 am   #11
CesarLG
CesarLG's Avatar
Now, the vibrator works after another cleaning... It sometimes doesn't start up, but I guess contacts will get better the more I use it.
I would like to know if you guys connect ve- to the wire that is connected to chasis... This is what I did. I have read that many car radios had the ve+ connected to ground... That is why I ask.
Ok, Now that I have vibrator on, and all tubes are warm and lit, I have no sound...
EA3IAV
CesarLG is offline
Old 30th Oct 2018, 9:44 am   #12
Station X
Station X's Avatar
The set should work with the battery connected either way round. It was not intended for use in a vehicle, but were it used in this way, deriving its power from the vehicle's battery, it would be prudent for the polarity of the radio's chassis, which is connected to the earth terminal, to match that of the vehicle's chassis.
First step in investigating the lack of sound should be to check for HT voltage. If there is none check for AC on the primary and secondary windings of the step up transformer.
Old 30th Oct 2018, 9:58 am   #13
Radio Wrangler
Radio Wrangler's Avatar
That vibrator has switches to work as a synchronous rectifier, so the polarity of HT you get can depend on the polarity of power you apply to the set. The vibrator may buzz happily but with the contacts grounding the wrong end of the HT winding each half-cycle....
Radio Wrangler is online now
Old 30th Oct 2018, 10:00 am   #14
Station X
Station X's Avatar
It's not used in that way though. The set has a valve rectifier.
Old 30th Oct 2018, 10:12 am   #15
CesarLG
CesarLG's Avatar
Sorry. I am a noob regarding tubes and old radios.
Should I check HT in the otput of every tube? I guess this point is the tip of the tube
At this point should I mention I have a signal injector? Is this handy for this checking purposes?
I guess there is a procedure with it starting from the speaker or the antenna on wards...
Name:	signal tracer.jpg
EA3IAV
CesarLG is offline
Old 30th Oct 2018, 10:19 am   #16
Station X
Station X's Avatar
You'll need a Digital Multimeter (DMM) to check the HT voltage.
Negative lead of meter to chassis and positive lead of meter to the smoothing capacitor. The cap is at bottom left of the extract from the circuit.
Old 30th Oct 2018, 10:33 am   #17
CesarLG
CesarLG's Avatar
OK C2A and C4A, those are that brown mica caps.
I will Check it as this afternoon when I get home
Thank you!
EA3IAV
CesarLG is offline
Old 30th Oct 2018, 10:49 am   #18
Herald1360
Herald1360's Avatar
The picture showed a 4-pin vibrator. Surely that has to be a non-synchronous type? Not enough legs for anything else.
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is online now
Old 30th Oct 2018, 10:51 am   #19
CesarLG
CesarLG's Avatar
yes, as far as I know it is non-sync
EA3IAV
CesarLG is offline
Old 30th Oct 2018, 11:05 am   #20
Station X
Station X's Avatar
Originally Posted by CesarLG View Post
ok C2A and C4A, those are that brown mica caps.
Thank you!
No. Those are mica caps. The smoothing cap is in the aluminium can.
