Reply
Old 25th May 2024, 12:09 am   #1
daveone23
Default Atwater Kent model 40
I rebuilt two model 40s and they both have the same problem: the volume is extremely soft. Both power supplies were rebuilt using the attached article, resistors and bypass caps replaced. All Voltages look good. Antenna transformers and volume pots look good. Connected to verified 80 foot long antenna. Any thoughts.
daveone23 is offline   Reply With Quote
Old 25th May 2024, 1:39 am   #2
Silicon
Default Re: Atwater Kent model 40
I am not familiar with these sets but I have a query regarding the output circuit.
The AC output signal to the speaker has to pass through a 2,200 Ohm resistor as it returns to ground (chassis or HT negative).
This seems wasteful. What type of speaker are you using?
Silicon is offline   Reply With Quote
Old 25th May 2024, 3:59 pm   #3
daveone23
I am using a 1920's RCA 103 mechanical speaker.
Old 25th May 2024, 7:37 pm   #4
Silicon
The 2,200 Ohm resistor is the automatic grid bias resistor for the UX-171A power Triode.
It is a directly heated cathode type of tube (valve).
That resistor is effectively wired between the cathode and ground.
The 'Return' wire from the speaker is effectively wired to the cathode of the UX-171A.
This looks strange to me, I would have expected it to be connected to chassis.
You could try wiring a non-polarised film capacitor (i.e. polyester) across the 2,200 Ohm resistor to see if it would improve the volume.
What is the Impedance of that RCA speaker?
Old 26th May 2024, 12:16 am   #5
daveone23
I tried a ground from the antenna connection to the mains and it helped the volume alot. Do you guys use grounds on your TRF radios?
Old 26th May 2024, 10:47 am   #6
Silicon
We need to be careful when we talk about the 'antenna connection to the mains'.
That sounds dangerous.
The terminology here can be different.
To me, protective earth, earth, ground, Antenna ground, chassis and HT negative are all different things.
In a 1950s AC radio they may all be connected together.
However in many other radios they are deliberately kept separate.
When I mentioned 'ground' in a previous post I meant 'signal ground'.
We need to know exactly what you meant in your last post.
Old 26th May 2024, 1:29 pm   #7
paulsherwin
paulsherwin's Avatar
There are very few AK radios around in Britain, so expertise on this forum will be limited.
Generally speaking, 'earth' (UK) = 'ground' (US). There may be more subtle differences in terminology that I'm not aware of though.
paulsherwin is offline   Reply With Quote
Reply
