Reply
Old 16th May 2024, 5:36 pm   #1
mediaseller
Default PYE P35 Cambridge Restoration
Hi, I wonder if anyone can help please?
I'm restoring one of these, and although I took plenty of pictures before I started, I'm having difficulty locating C45 on the underside.
Even though I have the schematic and layout, it's still difficult. Does anyone have photos of the underside of this model.
I found one on Radiomuseum, but the only picture is fuzzy and has a watermark. You can't download it.
Thanks in anticipation.
mediaseller is offline   Reply With Quote
Old 16th May 2024, 5:51 pm   #2
Station X
Station X's Avatar
Default Re: PYE P35 Cambridge Restoration
Which service sheet are you using?
Graham. Forum Moderator
Station X is online now   Reply With Quote
Old 16th May 2024, 6:28 pm   #3
mediaseller
Hi.
PYE P35 Service Sheet purchased and downloaded from this site. It doesn't say Cambridge.
The ones on Radiomuseum are not much better.
See this link https://www.dropbox.com/scl/fi/570i3...=4yn0ruy3&dl=0
Old 16th May 2024, 6:53 pm   #4
Cobaltblue
Cobaltblue's Avatar
You can't see this capacitor on the Radiomuseum picture.
It may be hidden in some heatshrink.
It's the tone correction capacitor and it may have been put directly onto the tags of the output transformer either by the restorer or the manufacturer.
under the chassis it would go from the HT connection of V5 to the anode of V4.
Snips attached from the trader sheet and the PYE sheets.
Mike T
Name:	Screenshot 2024-05-16 184336.jpg
ID:	297664   Click image for larger version
Name:	Screenshot 2024-05-16 184552.jpg
Mike T BVWS member.
www.cossor.co.uk
Cobaltblue is online now   Reply With Quote
Old 16th May 2024, 7:17 pm   #5
mediaseller
Hi.
Many thanks. I think I've sorted it out now.
I'll just wait for the blue flash when I switch on. LOL
Old 16th May 2024, 8:19 pm   #6
mediaseller
What a bummer.
Spent a week on and off, replacing waxy caps and re-stuffing the filter cap, only to find that the mains transformer primary winding is open circuit internally at the start of the winding.
It's a basic error that I should have checked this before commencing. Oh well, it's all good experience. It's my first time fixing a valve set.
Unlike David Tipton on YouTube, I haven't got the equipment or materials to rewind it.
Old 16th May 2024, 8:30 pm   #7
Cobaltblue
Cobaltblue's Avatar
These big PYE's turn up in poor condition its worth putting a request in for a replacement transformer as a wanted post.
its not a particularly big transformer so a Sub should not be too hard to find.
Mike T
Mike T BVWS member.
www.cossor.co.uk
Old 17th May 2024, 8:02 pm   #8
Ed_Dinning
Hi, if you are not too concerned about originality it should be possible to find a similar transformer that can be grafted in space permitting. A much cheaper solution than a rewind,
If you have no success in the next few weeks PM me and I'll see what I have in my used/ tested stash
Ed
Ed_Dinning is offline   Reply With Quote
Old 17th May 2024, 8:10 pm   #9
paulsherwin
paulsherwin's Avatar
It's just a 4+R superhet despite the tuning scale, so most scavenged transformers should work. You may need to use a different rectifier or use silicon if the transformer doesn't have a 4V winding.
paulsherwin is online now   Reply With Quote
Reply
