Reply
Old 12th May 2024, 10:43 pm   #1
RadioHist
Default Matching Brown microphonic amplifier to 2000 ohm
I have collected three variants of the S. G. Brown Carbon capsule Microphonic Amplifiers. Two of them are designed to work with 120 Ohm loudspeakers. I do not have the 120 Ohm variety (only 2000 Ohm) I presume I need a matching transformer 120 to 2000 Ohm for maximum power transfer. However, I have yet to find such a transformer. I also presume I am not the first to encounter this problem. What is the source of such a transformer? I'm thinking the primary need handle a few tens of milliamperes.
Comments welcome.
Robert
RadioHist is offline   Reply With Quote
Old 14th May 2024, 11:59 am   #2
Herald1360
Herald1360's Avatar
Default Re: Matching Brown microphonic amplifier to 2000 ohm
Sounds like you'll need a transformer with about 1:4 ratio, primary to secondary. Not ideal, perhaps, but a small 120V to 30V mains transformer, using the 30V secondary as primary would probably work well enough.
Looking at a circuit found online suggests that the amplifier already has a transformer output so dc shouldn't be an issue (unless the circuit is for a 2000ohm output amplifier and the 120ohm version has none) but even so a relatively small (25VA perhaps) TX should be OK. They work well enough to use as a bodge fix output transformer for a small single ended valve (tube) amplifier or radio.
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline   Reply With Quote
Reply
