Reply
Old 10th May 2024, 9:21 am   #1
mancunian69
mancunian69's Avatar
Default Ekco A455
Hi all, I have an Ekco A455 solid state set in for repair.
I have recapped all the electrolytics, powered it up and all I can hear is white noise, no audio.
Does anyone have an idea what I can do next?
I have a feeling it could be something to do with the IF module.
Rgds
Michael.
mancunian69 is offline   Reply With Quote
Old 10th May 2024, 9:30 am   #2
dazzlevision
Default Re: Ekco A455
The Mullard module contains AF11x series transistors which are subject to the "tin whiskers" effect. You could try tapping the module to see if that causes a response (sometimes the radio bursts into life for a short time). Almost all of the radio's RF and IF circuitry is inside this.
Otherwise, try a finger hum test on the volume control's slider (set to max vol). If that produces a hum, then the module is very likely faulty and will have to be opened up.
dazzlevision is offline   Reply With Quote
Old 10th May 2024, 9:34 am   #3
sexton_mallard
sexton_mallard's Avatar
Location: Ellesmere, Shropshire, UK & Co. Cork, Ireland.
Check the wavechange switch as well. This is a problem on my A455 where it is intermittent and all I hear is static when it 'breaks'.
Dom
Less snakes...more ladders!
sexton_mallard is offline   Reply With Quote
Old 10th May 2024, 9:43 am   #4
Station X
Station X's Avatar
Check voltages?
Inject signals?
Graham. Forum Moderator
Station X is online now   Reply With Quote
Old 10th May 2024, 11:27 am   #5
Nickthedentist
Nickthedentist's Avatar
Originally Posted by Station X View Post
Check voltages?
Inject signals?
This book will tell you all you need to know, in a very down to earth way:
https://www.vintage-radio.info/download.php?id=361
Apologies if you know much more about radio repair than you first post led us to believe
Nickthedentist is online now   Reply With Quote
Old 10th May 2024, 11:36 am   #6
paulsherwin
paulsherwin's Avatar
As said in #2, it's very likely that one or more of the AF11x transistors is bad. I've no idea how easy it is to get inside the module with this model. There's plenty of info about AF11x problems and solutions if you search the forum.
paulsherwin is online now   Reply With Quote
Old 11th May 2024, 2:52 pm   #7
mancunian69
Thanks guys. I will look into it further.
I can say right now that the white noise level is the same regardless of the volume position. I'll take a look and the band selector next before opening the module.
Michael.
Old 11th May 2024, 3:10 pm   #8
paulsherwin
Ah, constant white noise unvarying with the volume setting normally suggests a bad transistor in the first AF stage (OC75?). Any OC71/AC126 type should be OK - just try whatever you have to hand.
Old 12th May 2024, 6:33 pm   #9
mancunian69
I don't normally work on solid state sets and have no transistors at all. I'll have to look online, unless of course a member would like to donate one.
I have the IF module out now, which wasn't difficult. I will try the A/F idea before the module.
Reply
