8th Jul 2013, 10:00 pm | #1 |
Philips Krefeld factory does it still exist?
At the moment I'm in Germany, not far away from Krefeld. I had to search the net, but couldn't find any current information abut the old Philips factory. I asume it's closed, but when and what is happening there now?
According to this it must have been a Mayor plant: http://www.radiomuseum.org/forum/phi...feld_1973.html Were the Picture tubes also produced in the area? |
8th Jul 2013, 10:09 pm | #2 |
Re: Philips Krefeld factory does it still exist?
In the early eighties, TV production in Krefeld (KR) was "eingestellt" as they say in Germany. I think the E2 and K35 chassis were among the last produced there. The factory was converted to producing VCC and VHS recorders, competing internally with the Vienna factory. It was in operation at least until the early nineties. After that the German VHS activities were moved into an - apparently short lived - joint venture with Grundig located in Neurenberg (RJ). After that, I don't know of any activities in Krefeld allthough it is possible the factory was again switched to produce other goods. Chances are, it was closed down a long time ago (could be even 20 years, following the above timeline).
Some time in August, I will visit my uncle whose brother worked in Krefeld. Even though indirectly, I might be able to obtain some information or documentation. This could potentially take a long time as I'n not sure how often my uncle sees his brother. Last edited by Maarten; 8th Jul 2013 at 10:17 pm. |
8th Jul 2013, 10:44 pm | #3 |
Some searching learned that in 2010 the Philips factories in Krefeld-Linn (KR) were abandoned for some time already, and that development was imminent. See http://www.rp-online.de/niederrhein-...aende-1.711310 in which the 3 roads around the factory terrain are named and a picture is shown.
The approximate map coordinates of where I think the entrance to the (apparently still existing but in the mean time redeveloped) factory terrain would be, are: 51.336859, 6.635753 The picture tubes were produced in Aachen (VB). Picture tube activities ended in 2006 and again in 2008. Aachen (according to http://de.wikipedia.org/wiki/Philips_Deutschland in which Krefeld isn't mentioned at all) produced picture tubes until 2004 and glass until 2006. Last edited by Maarten; 8th Jul 2013 at 11:04 pm. |
9th Jul 2013, 2:09 am | #4 | |
Classic TV Show Theme Tunes |
10th Jul 2013, 9:20 pm | #5 |
I went by the factory today. It is still there and seems to be just as when Philips left. Some of the buildings are in use by small businesses, but the signs say large parts are available for rent.
The older buildings aren't well maintained. The roof is patched and in one place a bush is growing on the roof. The area arond the factory is a nice, well kept recidential area. It is just a matter of time before the older production halls are "redeveloped" into flats. There ar few signs of this being a Philips plant. On one door I saw a sticker, see photo, which seems kind of recent. |
11th Jul 2013, 1:49 pm | #6 |
Nice detective work, Hans!
11th Jul 2013, 1:54 pm | #7 |
Hi
Forgive my ignorance, but does the K (as in K35, K70 etc) denote Krefeld? We can only guess at what went into the skips when they left - or, tantalisingly, what might still be inside! As far as I know there's little left of the Croydon factory. Glyn |
11th Jul 2013, 3:13 pm | #8 |
Nope,
K is from "Kleur" (colour). Jac |
11th Jul 2013, 3:46 pm | #9 | |
The administrator building and the newer part of the factory can have further life left, but the older production halls by the main road are as mentioned in bad shape, but are still being used to some degree. (Logistc sentre/storage?) The plant was sold about 10 years ago but for some reason the owners haven't been able to fullfil their plans. Judging by the "for let" signs "redevelopment" is probably some years ahead. |
11th Jul 2013, 3:47 pm | #10 |
I assume G is from "Great Britain"?
11th Jul 2013, 3:49 pm | #11 |
11th Jul 2013, 8:50 pm | #12 |
11th Jul 2013, 9:33 pm | #13 | ||
To add or remove some confusion:
The letters in the chassis names don't have to ccorrespond to the letters in the model numbers. In case of the G for Great Britain and for example the GR for Global Range the letters are the same. In the older system, the letters K and T were used to denote colour (K for Kleur) or monochrome (T for Television), while additional letters such as A (Austria) D (Germany) G (Great Britain) S (Sweden) V (South Africa) X (The Netherlands and Belgium) indicated the country of commercial origin. An overview of those letters can be found at Philipsfan's site. Additionally, in front of the serial number, still other letters are used to denote the factory of origin. I mentioned those in brackets behind the factory locations in my last post. Some relevant letters combinations are: A = Eindhoven AG = Brugge NF = Norrkoping KR = Krefeld RJ = Nuerenberg VN = Szekesfehervar WD = Wien Quote:
11th Jul 2013, 10:11 pm | #14 |
There was only the sticker on the door and three parking spaces still reserved for Philips that were the only sign of them ever being there. The administration building is used, probably among others, by a debt collecting company.
The other buildings were used by the Dekra academy, a company making hydraulic hoses, someone doing machine repair, The German Railway had some stickers on some windows and at the lot behind the factory it seemed to be stored some train weels. There were some other companys too. I felt I couldn't stay too long and snoop too much as someone might had believed I had bad intentions. I was there at about 5 pm and I only saw two persons there, and somoene taking photos and wandering about might cause interest. |
11th Jul 2013, 11:15 pm | #15 |
Such a shame. When I worked for Philips in Croydon, we were always in contact with Krefeld regarding VCR's and modifications. When I think of all the expertise that was there....!
Rich
12th Jul 2013, 8:29 am | #16 |
The following pages may help in the ID process (I'm always looking to update my site where new/revised data is available):
http://www.philipstv.org.uk/blog/ear...els-directory/ http://www.philipstv.org.uk/blog/ear...del-directory/ Cheers Robert |
16th Jul 2013, 6:28 am | #17 |
If you are still in Germany please visit Aachen, not far away from Krefeld. They just started to destroy the Philips CRT factory! Best regards, German Dalek
And now something completly different: MARC BOLAN, he was/is the real king of Pop Music! |
16th Jul 2013, 11:25 pm | #18 |
What a shame. I think half of the sets I worked on had tubes from there. I was thinking of going there too but had to leave on Friday. On my way to/from Krefeld I saw sings to Aachen and wanted to go there but the traffic was horrible and I had an appointment later that day. I'm going back in some months but by then it probably is too late.
23rd Jul 2013, 12:45 pm | #19 |
If it's of any consolation: I visited Barcelona and wanted to take some pictures of (and possibly explore for any leftovers) the abandoned Tecnimagen (formerly Philips) site. Turns out I got it wrong (by about a block) and took pictures of the wrong building only to discover I did after I was already back home.
Anyone planning a visit to Barcelona? |
24th Jul 2013, 2:39 pm | #20 |
I might be up there in Novermber or December.
Regards, Ben. |
