Reply
Old 29th Mar 2010, 12:50 pm   #281
jakamp58
Default Re: The "Sussex" Homebrew Valve Tester.
How about part number. 815820 - 89 or similar toolcase at http://www1.conrad-uk.com/scripts/wg...max_results=20
for a case? You have them with plywood at the inside, so you can glue supports into the case to mount all the hardware.
Jan
jakamp58 is offline   Reply With Quote
Old 29th Mar 2010, 9:52 pm   #282
Guitarist28
Guitarist28's Avatar
Hi all,
Please note that D6 & C8 are orientated the wrong way aound in my xray diagram that I posted from an earlier post to this thread (thanks Andymic for spotting D6)
Regards
Rob
Guitarist28 is offline   Reply With Quote
Old 29th Mar 2010, 10:36 pm   #283
Guitarist28
I've lost the will to live.
I've swapped D6 around and its still not right - the values for TR6 and 7 are still low! Am I measuring from the correct place (0V at AB)??
Rob
Old 29th Mar 2010, 10:55 pm   #284
FRANK.C
FRANK.C's Avatar
Hi Rob
If your using a 9V battery to test the oscillator it might be best to lift one leg of ZD10 to take it out of circuit. Then apply the battery directly across C3. You can then take measurements with the negative lead of your meter. The positive lead clipped to the positive of the battery. The readings that you will get will be slightly different to Mikes because of the higher supply voltage from the battery.
Frank
EDIT:
Sorry should have said take measurements with the positive lead of the meter and connect the negative lead to the battery positive
Frank
FRANK.C is offline   Reply With Quote
Old 29th Mar 2010, 11:42 pm   #285
Guitarist28
Hi Frank,
Thanks for the advice - I'll try this tomorrow and post results accordingly.
Regards
Rob
Old 30th Mar 2010, 12:12 pm   #286
Guitarist28
I followed Franks advice and removed a leg from ZD10. The readings seen were as follows:
TR6 - Coll -3.16, Base -0.65 & Coll -0.05
TR7 - Coll -OL, Base -OL and Coll -2.43
Is TR7 getting to much of a wallop from the 9v battery or do I have another problem in the circuit??
Regards
Rob
Old 30th Mar 2010, 1:08 pm   #287
FRANK.C
FRANK.C's Avatar
Hi Rob
I'm not sure about your readings as you have 2 coll. for each transistor and no emitt. Each base and emitter should about .6V apart if they are substantially more than that the transistor may be open circuit. Although looking at the one reading that you have for TR7 it appears to be passing near the right amount of current (assuming the second coll. is actually the emitt). Are you sure the probes are making good contact when measuring TR7 coll. and base.
The voltage measured at TR7 coll. should be equal to the voltage across the battery.
TR6 voltages looks OK
Frank
Old 30th Mar 2010, 1:28 pm   #288
Guitarist28
Hi Frank,
The figures should read coll/base/emit and coll/base/coll (I was in rush to go out when I posted!!).
I'll have a go at TR7 again
Rob
Old 30th Mar 2010, 1:31 pm   #289
Station X
Station X's Avatar
According to your last post you still have a transistor with two collectors.
Graham. Forum Moderator
Station X is online now   Reply With Quote
Old 30th Mar 2010, 3:40 pm   #290
Guitarist28
Sorry Graham et al.
I must learn not to post whilst I am about to leave the house to go to the doctors/physio/swim in future.
What I should have written was as follows:
TR6 - Coll -3.16, Base -0.65 & Emit -0.05
TR7 - Coll -OL, Base -OL and Emit -2.43
I am going to take the readings of TR7 again.
Regards
Rob
Old 31st Mar 2010, 11:58 am   #291
Guitarist28
I finally managed to get of reasonable readings from TR6 & 7
TR6 E -0.06, B -0.68 & C -1.64
TR7 E -1.04, B -1.56 & C -9.24
I assume the results will vary depending how good a connection can be achieved on C8 which not easy as I trimmed the leads really short. I really need to get to grips with some basic circuitry understanding so I think that a lot more reading will be in order.
Regards
Rob
Old 1st Apr 2010, 1:39 pm   #292
julie_m
Default Selector Switches
(I was going to ask this in a PM, but I thought it relevant and interesting enough to post openly.)
I note you say that your selector switches are set up "the same as the AVO CT160". What exactly does that mean? I'm taking it that there is one switch per valveholder pin, and each numbered position is one of the test voltages; but what is the meaning of each numbered position?
I ask because I'm building my own valve tester, not quite to your design (diversity is A Good Thing™) but some measure of compatibility is A Good Thing too. I'm thinking the easier it is to adapt a test schedule written up with one model of valve tester in mind for another tester, the better.
julie_m is offline   Reply With Quote
Old 1st Apr 2010, 6:28 pm   #293
Top Cap
Top Cap's Avatar
Attached a rough and ready copy from the AVO manual which may be of help.
Les
Name:	AVO 160 rollers.GIF
Whether the Top Cap is Grid or Anode - touching it will give you a buzz either way!
Top Cap is offline   Reply With Quote
Old 1st Apr 2010, 7:31 pm   #294
julie_m
Thanks; that makes perfect sense!
Old 5th Apr 2010, 11:16 pm   #295
Guitarist28
At last, my circuit board is indeed oscillating (see attached) although needs a little tweaking to be perfect.
The case now to be built......
Rob
Old 7th Apr 2010, 3:01 am   #296
thor1961
Are "US" transformers still available if so what is the cost and how can I purchase one?
thor1961 is offline   Reply With Quote
Old 7th Apr 2010, 6:49 pm   #297
Ed_Dinning
Hi Thor, I've wound some for the US market, cost is exactly the same at £50.
Primary is 115, 120, 125 and an extra 2.5V tap is added in the heater winding to cater for the audio triodes.
Postage costs are typically about £40 for surface freight and £70 for cheapest airfreight.
It may be cheaper to have 2 or more wound and reduce the cost that way. PM me if you need more details.
I will keep these transformers available for the foreseable future
Ed
Ed_Dinning is offline   Reply With Quote
Old 10th Apr 2010, 3:29 pm   #298
Top Cap
Top Cap's Avatar
This is my effort so far, still waiting for my bonus at work to invest in a case and meters . I decided to use fan assisted cooling to keep the heat sink smaller, this being run from the 12V heater supply. You can see the additional rectifier and capacitor mounted between the relays on the piggy back board. I might fit a thermostat to the sink wired to the HT relay so if the fan fails and the sink over heats then the HT will be cut off. I also considered servicing if any of the devices fail so decided to modularise the whole thing, interfaced with a 50 way D connector. The photos show the whole prior to wiring, just hope it looks just as neat when it is fully wired up.
When full construction takes place I am considering wiring all G1 wiring with single core screened cable. Also using 9 separate screened wires between the pin selector switches and the valve holders. The latter I hope to wire with spaced standard single wire but I happen to have a bag of ferrite beads so may be tempted to fit one at each valve socket connection. Hopefully this may stop any tendency for parasitic oscillations, or am I going a bit OTT?
Les
ID:	34306   Click image for larger version
ID:	34307   Click image for larger version
ID:	34308   Click image for larger version
Old 10th Apr 2010, 6:31 pm   #299
Andymic
what a damn fine bit of construction.
Well done!
Andymic is offline   Reply With Quote
Old 10th Apr 2010, 6:57 pm   #300
MichaelR
MichaelR's Avatar
Les ,
You Have done the design justice with that neat construction, very professional.
For the sake of minimising parasitics I am going to use screened cable as well, there is nothing worse than trying to cure parasitics when you have them in circuit.
Mike
MichaelR is offline   Reply With Quote
Reply
