Old 17th May 2019, 6:53 am   #61
Radio Wrangler
Radio Wrangler's Avatar
Default Re: Power MOSFETs
The interesting factor is that the damping factor of an audio amplifier is broadband. The output impedance might start ncreasing towards the top end of the audio range as loop-gain gets lower, but it won't be bad. The amp will respond well to load fluctuations.
The original scheme of a carbon pile reg operated by a solenoid can only respond slowly to load variations, so the supply is essentially unregulated in the short term.
The avionics gear being powered had to be designed to work with the latter scheme, so a big audio amp would be TLC in comparison.
Radio Wrangler is offline
Old 17th May 2019, 10:18 am   #62
Argus25
No Longer a Member
Originally Posted by Julesomega View Post
I think what we are discussing here is the Damping Factor of an audio amp. The one I have offered is spec'd as "@1kHz into 8 ohms >400" which implies an output impedance <0.02ohm
MC1250
That is pretty good.
Argus25 is offline
