Old 6th Apr 2019, 5:13 pm   #21
Simon Gittins
Default Re: Ferguson 382U Firefly not playing ball
The idea about the 220pF capacitior was always a long shot, best to continue logical fault finding.
Is the V3 anode voltage stable now? If the variation is repeatable it's worth checking R14.
Simon Gittins is online now
Old 6th Apr 2019, 5:35 pm   #22
PJL
Other than the odd 100V, the DC conditions on V3 look good, the screen grid current is directly related to the anode current so the correct voltage on the screen grid indicates it is conducting OK.
Set to MW again, check the V2 screen(1) but I suspect it will be OK.
At this point it would be a good idea to check your capacitor replacements were done correctly. You said you replaced C16 but I suspect you meant C17?
It's also worth checking all wavebands to see if anything is happening as it might help narrow down the fault.
Touch each grid with your meter probe with the other probe disconnected (be careful). starting at V5 and working backwards. Using your meter as an aerial should pick up some noise so I would expect a click or even hiss.
PJL is offline
Old 8th Apr 2019, 10:50 am   #23
el gringo
Hi thanks for suggestions,
V2 Screen = 138V
However discovered what I believe to be "R11" (3k3) was in fact measuring 17.7k - replaced, although no apparent effect.
Pete
el gringo is offline
Old 8th Apr 2019, 11:39 am   #24
el gringo
R14 actually seemed O/C, so added a 4k7 ( nearest value I had ) in parallel and now THAT also seems O/C when in situ
Disconnected the 4k7 and pulled one leg of the original 3k3, now R14 reads around 4k..?
I have no idea...
Pete
Old 8th Apr 2019, 12:34 pm   #25
Boater Sam
Erroneous meter readings,,,,,, Check the meter against a known voltage, inspect leads for breaks.
O/C or S/C? infinite ohms or zero ohms?
Boater Sam is online now
Old 8th Apr 2019, 1:08 pm   #26
PJL
R14 is V3 anode feed resistor and you have already noted that the anode voltage dropped to 100V at one point. Check for poor connections.
I would like to go back to your capacitor replacement list as you appear to have missed some:
* C16 is marked as replaced but it is only 33pF (ceramic or mica) and unlikely to have failed.
* C36 (V3 screen decoupling) and C37 (V3 anode decoupling) should be replaced as both have quite high voltages across them and loss of capacitance will impact gain.
* C50 (audio decoupling capacitor) not critical but it is probably paper.
* C52 (output audio coupling capacitor) this is 'that' capacitor and should be the first you replace as failure will cause the output valve to conduct heavily with possible damage to the output transformer.
Not sure what type these capacitors are in this set so they may be OK? Would help us if you posted a picture of the underside.
PJL is offline
Old 8th Apr 2019, 3:10 pm   #27
el gringo
Thanks PJL!
Okay, after now finding the actual Ferguson Service Manual from "***********************"
I can now understand the circuit diagram with greater clarity!
Correction: R11 was in fact R7 and perfectly fine.! R14 is in fact s/c ( this is what the wavechange switch does, when set to MW (doh!)
C52 was in fact disconnected at one leg, component now replaced.
will now look at replacing C36,C37 and C50
Pete
Old 8th Apr 2019, 3:22 pm   #28
PJL
My references all relate to the circuit in trader 1299. If C52 in the trader was disconnected it is not surprising that it was not working as this feeds the audio to the output valve.
PJL is offline
Old 8th Apr 2019, 4:22 pm   #29
el gringo
C36 and C37 and C50 now replaced.
Old 8th Apr 2019, 5:13 pm   #30
el gringo
Just to confirm a sig generator on to the grid of V4 gives a nice loud output.
Pete
Old 8th Apr 2019, 5:53 pm   #31
PJL
Do you still not have any reception on any waveband? If not can you check your capacitor replacement carefully.
As DC measurements look OK and your audio stages work, it looks like an RF problem. My only reservation is that FM and AM use separate signal paths so finding the fault may be tricky. I guess you do not have an RF signal generator?
PJL is offline
Old 8th Apr 2019, 7:09 pm   #32
el gringo
Hi PJL, no unfortunately I don't. I have a a 20Mhz (allegedly) DSO which has a built in sig generator - but only to 20Khz.
I'll go check each cap that hasn't been replaced - although if I could eliminate everything in that shielded RF can, that would be a bonus, or do you reckon its worth dismantling it just in case?
thanks, Pete
Old 8th Apr 2019, 9:48 pm   #33
PJL
It was checking your wiring of the capacitors that you have replaced that I had in mind. It is easy to wire one to a wrong pin and kill the RF signal.
PJL is offline
Old 8th Apr 2019, 10:06 pm   #34
Mike. Watterson
Ah, so taking into account sampling, two channels etc, it's equivalent to a 500 KHz analogue scope that can display a square wave!
You can use another radio as a signal gen. Put about 5 turns of wire around a small transistor set to pick up its L.O. It will be 455KHz off the dial frequency.
Mike. Watterson is offline
Old 8th Apr 2019, 10:25 pm   #35
Simon Gittins
I wouldn't recommend that. Once you open the can, you will upset the alignment to some extent. In my case all those years ago, I used a signal generator to prove the fault to the IF stage, confirmed all voltages were correct and then established that one winding wouldn't tune so I knew that it had to be a faulty capacitor in the can.
Checking your previous work and using another radio to help prove the fault to one particular stage sounds like the best plan.
Old 9th Apr 2019, 9:46 am   #36
jonnybear
jonnybear's Avatar
Reading your replies,It is very simple when replacing a component to connect to the wrong point we have all done it, it would help if you could download some pictures of the radio and work carried out, as it is possible someone may spot your problem, you can go round and round in circles and still miss something.
The worst fault to find is man made.
John
jonnybear is offline
Old 10th Apr 2019, 3:41 pm   #37
el gringo
Here's the now very scrappy looking set
( will of course be tidied up, once I can get it working )
Old 10th Apr 2019, 3:47 pm   #38
el gringo
Hi Mike - I've given that a try, with the "sig gen" radio on MW and trying the grids of the RF section (inc the detector stage). The only thing I get is light clicking induced in to my "sig gen" radio speaker?
thanks, Pete
Old 10th Apr 2019, 4:27 pm   #39
PJL
Can you do a couple more pictures as the resolution is not quite good enough. Maybe two pictures one of each end of the chassis would work. There are still a few wax capacitors in the set?
PJL is offline
Old 10th Apr 2019, 6:34 pm   #40
el gringo
Hope these are a little clearer..
There are only two Wax ones left, however they're not grounded
thanks, Pete
ID:	181183   Click image for larger version
