25th Feb 2007, 10:43 pm | #1 |
Pye 39J/H dial lamp diffuser.
I found this radio fly-tipped today and it is basically in excellent mechanical and cosmetic condition. (Haven't done any more to it yet than clean it up.)
However there is (or was) a sort of paper-thin opaque membrane behind the dial glass which is clearly to diffuse the light from the four dial bulbs which are at the sides of it and this has completely disintegrated into tiny pieces. Can anyone suggest a suitable replacement substance. Obviously it must be heat-proof. Thanks to all.
Now that's the kind of Long Wave I like ! (Severn Bore near Gloucester) |
26th Feb 2007, 1:23 am | #2 |
Re: Pye 39J/H dial lamp diffusing membrane totally in shreds.
I have had a similar problem with a Ferranti model 545 transportable radio. The answer seems to be the material used for heat-resisting lampshades. I have yet to fix my set, but a cheap lampshade will be sacrificed at some future date!
Congratulations on rescuing another old set from destruction and bringing it into preservation Phil
26th Feb 2007, 9:27 am | #3 |
Hi John - we use sheets of plastic translucent material as HT insulation card - it's about 0.5mm thick and might do the trick for you as it's a slightly off-white colour.
Waring Last edited by Darren-UK; 12th Sep 2007 at 4:59 pm. Reason: Ref to PM removed. |
26th Feb 2007, 11:26 am | #4 |
On a Pye PE41 (export A39j/h) I used a piece of mylar drafting film. It has been ok so far. The radio is on for a few hours per day.
Graham Last edited by Darren-UK; 12th Sep 2007 at 5:00 pm. Reason: Ref to PM removed. |
