7th Sep 2016, 10:38 am | #41 |
Re: Hi From Cathy Lissen/Eveready Kenilworth??
It's all looking good so far. The o/c output transformer may be why the radio went out of use and there may not be any other actual faults, just age deterioration.
Examine the transformer carefully. They sometimes go o/c close to the solder tags and can be repaired quite easily. If you need to replace, don't be overly concerned about the turns ratio as this is a lot less critical than is often assumed. There will be an ideal ratio depending on the ideal anode load impedence and the speaker impedence, but you can be as much as -50+100% out and still get reasonable performance. The only effect will be a reduction in maximum volume which may not even be audible. |
7th Sep 2016, 10:49 am | #42 |
Thanks for recent replies. Yes I have a mains 1kVA isolation transformer and various 'Variacs', so that I can gradually 'wind up' the voltage, after I have isolated the secondaries. I am surprised that the Trader Sheet doesn't quote AC secondary outputs. Always used to ask our 'trainees' How come you can get greater than 240 vac out of a Variac given that the input voltage is measured at 240v? Used to cause some head scratching that one, as they assumed it's just a simple potential divider (which it isn't) ! If I add power resistors to 'load' the output windings, then what is a realistic current to draw to give the Tx a 'bench soak' before proceeding any further ? Adding up the anode currents I was thinking 60 mA for the HT winding or is this too simplistic or excessive? I won't do anything without the blessing of you guys.
BTW my old pal Les, a radio amateur, who sadly passed away a couple of years back, and gave me that NOS audio Tx, used to call transistors 'three-legged-fuses'. He would have been in his element with this radio. He used to go into a shop on Hedon road in Hull as a boy to get his valves tested & in the '70's I remember a lady in that same shop still carried out valve testing as I gather her husband was no longer around. |
7th Sep 2016, 10:56 am | #43 |
Hi from Cathy ... told you he would 'warm' to this project . A big thank you to everyone on here for spurring him along. I got home last night at 10.45 to find him 'tinkering' ..just like my dear old dad used to do when I was small. Certainly brought back fond memories. Just can't wait for that characteristic smell of old hot valves, wood & dust !
7th Sep 2016, 11:07 am | #44 | |
The heater winding voltages can be derived from the heater voltages of the valve types used, here's one of the bibles for online valve data: http://www.r-type.org/index.htm EDIT: Here's the other bible: http://www.shinjo.info/frank/ Lawrence. Last edited by ms660; 7th Sep 2016 at 11:18 am. |
7th Sep 2016, 11:56 am | #45 |
Ash here... how critical are capacitance values in the smoothing cap block? When I used to build transistor amps in my youth the larger the capacitance value of the reservoir capacitor in the power supply the better. Or do you have to watch out for inrush if a larger value is used, on initial power up, with such a high voltage winding?
7th Sep 2016, 12:05 pm | #46 |
Not massively critical - as mentioned earlier, high value capacitors of this age have a huge tolerance, often as much as -50%/+100%. So take the value in the circuit diagram and pick then nearest available capacitor if you can't get the exact value.
7th Sep 2016, 12:30 pm | #47 |
Don't go wild with the reservoir cap value, too big will over-stress the rectifier valve.
Smoother can be a good deal larger than the original, the choke or resistor will limit the charge current effectively. Older sets had small values because electrolytic caps were expensive, cheaper to tolerate a little hum! |
7th Sep 2016, 12:33 pm | #48 | |
Les OOPS! Cross posted
7th Sep 2016, 1:30 pm | #49 |
Hi from Ash... just ordered up all of the electrolytics in the set, went for best quality I could find in stock. I got three 10uF Vishay 'ATOM' 450v ones for rebuilding the smoothing block cap.
7th Sep 2016, 6:56 pm | #50 | |
The reason that the rectifier valve has a separate heater winding is that if you look at the circuit, and the depiction of the rectifier's internal construction, you will see that the valve has a 'directly heated' cathode. This means that the rectifier heater and cathode are connected internally, and as well as there being 4 Volts DC from the transformer heater winding, you will see that the raw DC HT also appears on the heater winding, from whence it goes to the smoothing choke and the reservoir/smoothing capacitors. Hopefully, the output transformer failed while there was still life left in the valves! Great progress so far - good luck with further steps along the road of your 'voyage of discovery' Ash!
7th Sep 2016, 7:21 pm | #51 |
Directly heated valves don't have a separate cathode structure, indirectly heated valves do.
Not sure how one would get 4 Volts DC from a transformer winding. Lawrence. |
7th Sep 2016, 7:58 pm | #52 |
Well got home from work and removed the O/P Tx . Stripped off the outer frame and small lamination set and unwound the secondary , photoing each layer. managed to locate both ends of the sec. but still infinite resistance so guess it is BER.
Scoured the garage for the 'RS Components' transformer and it's a 'STANDARD OUTPUT TYPE'. I have photo'd it and annotated the picture with the DC resistances of the primary and found an old RS cat. page on it. Do you folks reckon it will be any good, at least to try out the chassis? Just love that little RS man, remind me of making my first Xtal set as a schoolboy. The secondaries seem OK too but I would need my TTi bench meter to measure such low DC resistances & it's at work. Really getting into this now! |
7th Sep 2016, 8:04 pm | #53 |
It will certainly be OK as a stopgap. Some of these RS transformers had multiple taps so you could select the most appropriate turns ratio (I see from your pic that that one does).
Many forum members have boxes full of scavenged output transformers so somebody will probably be able to help you out if need be. Cross that bridge when you come to it though - let's get it working first. |
7th Sep 2016, 8:07 pm | #54 |
That transformer should do, somewhere on this forum there might be a full spec sheet for it, I'm sure I saw it the other day. Haven't got time to look right now but someone else might.
EDIT: Post crossed. Lawrence. |
7th Sep 2016, 8:44 pm | #55 |
Attached is the current universal transformer sold by RS. The terminal annotations are the same but not necessarily correct for your transformer but a good bet that they are. For an 8k Load for the A70D into a 3 Ohm speaker suggests using tags 1 and 3 for the primary and tags D and C for the speaker.
Looking at the circuit, I suggest you change all capacitors that see the HT, the three I have in mind are C12, C27 (both 100nF 400V) and C34 2.2uF 450V. This assumes you have already replaced the MUST DO THAT capacitor C35 47nF 400V. The Mica capacitors will probably be OK so don't change them just yet as alignment may be upset. Good Luck with this one, it looks a great set to recon. Les
8th Sep 2016, 12:04 am | #56 |
Bear in mind that the RS output transformer is only rated at 40mA primary dc. Luckily the A70D output valve normally runs at 36mA anode current, so all is fine. It needs an 8K optimum load which will certainly be close enough to one of the RS transformer ratios.
8th Sep 2016, 8:21 am | #57 |
Cathy here... feeling ever so slightly guilty, as I have got him totally obsessed with getting my radio working. I guess the challenge from you guys that he was 'biting off more than he can chew' is spurring him on. His posts are all gobbledygook to me but I am over the moon that he is using a part in it given to him by our sadly departed friend Les Miles.
Whist he is working on the gubbins inside I feel I should be cleaning up the cabinet. Any pointers please, like best stuff to sympathetically remove 70+ years of grime. Also the speaker front grille woven 'fabric' needs sprucing up ...any ideas here please. Same goes for the tuning scale & pointer. I would also like to source some material for the missing rear cover. Ash says he remembers a compressed board, something like hardboard but slightly different painted black on one side. We have still not found an image of another identical radio. Ash says he took Les once to a National Museum in Bradford which he remembered having vintage sets but Googling that, there appears to be removal of exhibits from there to the V&A. What is the best place/museum to see vintage sets at, which is open to the public please? x Cathy |
8th Sep 2016, 9:23 am | #58 |
A lot of Radio backs are made of a material like Millboard.
If you know of a local vintage car restorer you may be able to get some there or you can buy larger pieces here http://www.woolies-trim.co.uk. You will need to make some ventilation slots. There are several threads on this forum about reproducing backs. Cheers Mike T
8th Sep 2016, 10:00 am | #59 |
Some 1930s sets had a plywood back (with slots or mesh cloth covered windows for ventilation), so that might be an option. Otherwise hardboard with holes in it - known as pegboard is a common substitute for the proper back panel.
Effectively you just need something that'll let air flow in and out, but keep fingers and pets out. Be really careful cleaning the tuning scale - it's very likely that the dirt is the only thing holding the letters and numbers on My 1930's Invicta appears to have a gold plated tuning needle which is immaculate. The dial it moves over is some sort of cream plastic and has a cellulose based clear plastic window, which has gone yellow and shrunk a bit after 80 years or so. I chose to just use a soft cloth and plain water to gently lift the dust from those. |
8th Sep 2016, 10:30 am | #60 |
Great work so far.
As Rich said, be ever so careful with the tuning dial. Personally, I would remove it, clean the front with a rag lightly moistened with foaming cleanser, and do nothing to the screenprinted reverse except lightly dust it with a very soft brush. Some people replace the speaker fabric with new, but unless it's too bad, you're probably best leaving it as-is, keeping the set nice and authentic. Where to go to see old radios? Definitely the late Gerry Well's wireless museum in Dulwich, London. Have a look at the "Virtual Tour" here: http://bvwm.org.uk/ |
