Reply
Old 10th Aug 2023, 6:57 pm   #41
buggies
buggies's Avatar
Default Re: That ubiquitous "-Tron"
Two not yet mentioned
Solartron
Orgasmatron (Barbarella) - well it was keyboard operated...
George
buggies is online now   Reply With Quote
Old 10th Aug 2023, 7:03 pm   #42
duncanlowe
I'd just this second remembered Solartron, given I have a couple of bench DMMs of theirs.
duncanlowe is offline   Reply With Quote
Old 10th Aug 2023, 8:47 pm   #43
Graham G3ZVT
Graham G3ZVT's Avatar
Solartron
You are correct, the latter wasn't mentioned way back in Post #15
Originally Posted by G6Tanuki View Post
[OK, yes, the Jumbotron was an 1980s/90s big display used at sports grounds etc to show action-replays of contested referee-calls and the like; it was actually a trademark of Sony but since became a generic name for the things, like Hoover for vacuum-cleaners. See... https://en.wikipedia.org/wiki/Jumbotron ]
If you gave me the description, without naming it, I might have guessed "Eidophor".
Graham.
G3ZVT
Graham G3ZVT is online now   Reply With Quote
Old 10th Aug 2023, 8:57 pm   #44
factory
I've remembered we had an EIL Chronotron at work, sadly chucked only a couple of years ago.
There is an Austron time code generator in my collection, as well as a broken Huntron tracker and a Phaostron VOM (also made panel meters).
Almost forgot Systron Donner, another test equipment maker.
factory is online now   Reply With Quote
Old 10th Aug 2023, 9:04 pm   #45
Malcolm G6ANZ
Malcolm G6ANZ's Avatar
Apparently the suffix 'tron' is from the Greek meaning instrument.
Malcolm G6ANZ is offline   Reply With Quote
Old 10th Aug 2023, 9:40 pm   #46
m0cemdave
It wasn't in Barbarella...
m0cemdave is offline   Reply With Quote
Old 10th Aug 2023, 10:59 pm   #47
Bill
USA valve (tube) make: Hytron, got a couple of their 807s.
Bill is offline   Reply With Quote
Old 11th Aug 2023, 12:04 am   #48
Radio Wrangler
Radio Wrangler's Avatar
It was in The Sleeper. Barbarella had "The Excessive Machine"
Barbarella's space suit glass helmet was the same shape as the Western Elctric 717A vacuum tube, often used to soup-up the input RF amplifier of AR88s!
Radio Wrangler is online now   Reply With Quote
Old 11th Aug 2023, 8:55 am   #49
Paul_RK
Paul_RK's Avatar
Anyone seen a Teletron transistor portable? Five models are listed in Radio! Radio! as appearing between 1960 and 1964, with the first of them including SW, but I don't think I've ever met one and RM.org hasn't a single photo. Not Teleton, those exist in larger numbers and would be OT for the thread.
Paul
Paul_RK is offline   Reply With Quote
Old 11th Aug 2023, 10:01 am   #50
G6Tanuki
G6Tanuki's Avatar
Rectron was a brand name used by RCA for its early vacuum tube rectifiers, I notice that the name is now used by a Taiwanese manufacturer of solid state rectifiers.
G6Tanuki is online now   Reply With Quote
Old 11th Aug 2023, 7:05 pm   #51
duncanlowe
Not that I remember these: Pogotron, a game for C64 (and probably others). Not quite a fit, but Spiratronics. And relevant here. There is such a thing as a spiratron too. Musitron anyone? (synth). Tomytronic (Tony) did a version of a game based on Tron. Curvytron, another game. It seems think of a word, add tron, and it's already there!
Old 11th Aug 2023, 8:33 pm   #52
bluepilot
How about the Talkatron?
Talkatron
Has anyone mentioned the Godley Creme Gizmotron?
Stuart
The golden age is always yesterday - Asa Briggs
bluepilot is offline   Reply With Quote
Old 11th Aug 2023, 9:32 pm   #53
Joe_Lorenz
Has already the company "Emotron" been mentioned? GC Drives & Automation Emotron, a supplier and maker of fine VFD drives. Some years ago, I ran a project involving them. Their successfully finished task was to get four ac motors of 450kW @ 690V 3ph running synchronized between 150 and 980 rpm.
Joe
Joe_Lorenz is offline   Reply With Quote
Old 13th Aug 2023, 11:42 pm   #54
Pfraser
Anyone remember Plustron TVs? Small enough for camping etc, or some TV-DX chasing with their Band I/III + UHF model.
Pfraser is offline   Reply With Quote
Old 14th Aug 2023, 1:42 am   #55
Oldmadham
Originally Posted by SiriusHardware View Post
And a recent sequel as well.
'Tron' (or 'Tronic') is one of what I regard as the unholy trinity of bad brand name endings, eg, 'Lloytron' along with '..tone (As in Binatone) or '..sonic' (As in Kingsonic).
If you see any of those attached to the end of a brand name you can be virtually assured that it is low-end, if not actually junk.
Radiotron valves weren't junk, especially the AWV ones made in Oz.
AWA had a licensing arrangement with RCA to use the "Radiotron" & "Radiola" names.
On test, (AVO tester), the AWV valves were consistently better than spec, with Siemens next then US Radiotron, Sylvania, followed by Philips & EEV neck & neck, then Mullard, with Brimar a length or so behind!
These were brand new valves in the late 1960s, early 1970s.
Oldmadham is offline   Reply With Quote
Old 14th Aug 2023, 1:52 am   #56
Oldmadham
Originally Posted by emeritus View Post
The Emitron TV camera was the first one that came to my mind.
Specifically, the CPS (Cathode Potential Stabilised) Emitron, as my old Tech school Instructor, George Hatton, took pains to point out!
It was "just the duck's guts" in terms of camera tubes till the wondrous "Image Orthicon" came along.
Old 14th Aug 2023, 5:21 am   #57
Pfraser
The Compactron, a hollow state approach to integrated circuitry. Introduced by General Electric in 1960 and used (for example) in their Porta-Color set.
The Sharp Linytron TV. Discussed here.
Old 14th Aug 2023, 2:54 pm   #58
russell_w_b
russell_w_b's Avatar
Don't forget the Megatron: the saturable reactor-controlled capacitor discharge unit that delivers a 5us 359 Amp (peak) pulse to the business-end of the half-cycle generators of the Megapulse LORAN transmitters.
Easy to see where the 'tron' came there!
Regds,
Russell W. B.
G4YLI.
russell_w_b is offline   Reply With Quote
Old 15th Aug 2023, 1:18 pm   #59
DrStrangelove
After desperately attempting to remember the trigatron only to find it in the OP, how about the ignitron.
DrStrangelove is offline   Reply With Quote
Old 15th Aug 2023, 1:39 pm   #60
G6Tanuki
G6Tanuki's Avatar
Of course Megatron is the chief villain in the Transformers series, where he battles Optimus Prime for control of the planet Cybertron!!
Reply
