28th Jan 2011, 10:32 am | #1 |
R1155 HT supply
Just making up heater and HT supplies for this set. I have a 6.3V 4A heater transformer ready to go in so thats sorted. I have assembled a DC supply (transformer, bridge rectifier and 50uF/350V cap) that provides 240V at 80mA, this sits at about 340V on no load. On test with an external PSU the set is up and running very quickly, however I was concerned about wether having this amount of HT at start up was a good thing. Should I have a series load resistor or something? The set is only ever going to drive headphones so there is little extra load on the system.
Neil
28th Jan 2011, 12:05 pm | #2 |
Re: R1155 HT supply
You can use the PSU design software from the Duncan's Amps site to predict the effects of adding loading without guesswork or experimenting.
http://www.duncanamps.com/psud2/index.html If this is a simple 50µF filter it may not give that much smoothing and you might look at something else such as a two caps and a resistor, or adding a choke if you have a suitable one to hand. You can investigate with that software. Another possibility is to use an NTC thermistor to give a gentle start. When I had this problem I modified his solid state HV regulator to provide the HT. http://www.duncanamps.com/technical/mosfet.html Of course, if you've replaced the paper caps, having 340V across the HT+ and HT- may do no harm, but it would make me feel a bit uneasy - asking for trouble. Pete. |
28th Jan 2011, 12:36 pm | #3 |
Re: R1155 HT supply
Thanks for that Pete, I have downloaded the software. I may go for the two caps and choke approach, this would give the HT a bit of a soft-start characteristic or I could easily reduce the HT since the transformer is multi-tapped.
Neil
28th Jan 2011, 5:38 pm | #4 |
Re: R1155 HT supply
Please remember that the chassis of the 1155 is at bias potential - connecting HT- to the case will result in a seriously deaf RX!
28th Jan 2011, 5:48 pm | #5 |
Re: R1155 HT supply
Yes, a good reminder from Sean there just in case one was tempted to mount electrolytic cans straight to chassis. I have selected axial leaded electros which can be mounted such that -HT is kept clear of the chassis.
Neil
