21st Jan 2011, 9:00 pm | #1 |
Realistic Pro 2005/2006
I have just aquired a tatty Realistic Pro 2005 that works well except that the display has just about had it. I thought a replacement display would be simple but Internet searches suggest that the display (EL501) has long been discontinued. Any knowledgeable/creative souls out there who can suggest either an alternative part or a simple circuit to feed an alternative display? Any help more than welcomed.
Tom |
22nd Jan 2011, 9:37 am | #2 |
Re: Realistic pro 2005
Tom,
PM sent, hope it helps.
Dave G1AGK. My perception is my reality! |
24th Jan 2011, 12:06 am | #3 |
Tom
What is the problem with the display? If it is just the backlight, these are relatively cheap and easy to replace as use an Electroluminescent (EL) panel available on E-bay. I replaced mine a few years ago! If the LCD display is faulty, a slightly "over the top" but interesting project is to use a PIC and drive an Alpha numeric display. Ive replaced a few obsolete LCD displays this way, but only viable as a learning project! |
24th Jan 2011, 1:31 pm | #4 |
Thanks for the fast responses. David has pointed me to a source of replacement displays on the Internet (why didn't I find these?) which may solve the problem as it looks like the display itself, rather than the backlight has failed. I can just about make out the larger characters in the display when they change but after a few minutes the whole display blanks. I will follow David's lead but I would be interested in following up the PIC solution also as it's time to learn how to program and use these clever little devices. So where to start?
Tom |
