Old 7th Sep 2019, 10:10 am   #1
tonygillett
Default Grundig Yacht Boy 210N - values of capacitors C41 and C44
Hi all,
Can anyone tell me the definitive values of C41 and C44 in a Yacht Boy 210N?
The schematic (https://www.vintageshifi.com/reperto...ice-Manual.pdf) says 5uF, whereas when I test the originals they come out at approx. 10uF. The markings are not clear but they suggest 6.8uF 40WV I think (see attached).
Are the values not too critical so Grundig just popped in 6.8uFs, which over the last 50 years or so have crept up to getting on for 10uF (possibly not helped by being overrated from a voltage POV)?
Many thanks in advance,
Tony
ID:	189638   Click image for larger version
tonygillett is offline
Old 7th Sep 2019, 10:21 am   #2
paulsherwin
paulsherwin's Avatar
Default Re: Grundig Yacht Boy 210N - values of capacitors C41 and C44
That is 6.8uF. As you suggest, the value isn't critical, and may have been revised during production.
When electrolytics test high, that is usually an indication that they are leaky.
paulsherwin is offline
Old 7th Sep 2019, 11:27 am   #3
tonygillett
Thanks, Paul. I'll drop in replacements. The radio is in excellent physical condition but its sound is a little distorted so I thought I'd treat it to new electrolytics. Someone in the past has performed a rather clumsy AC adaptor modification unfortunately, but I don't think I'll get involved in reversing that.
Anyhow thanks for your help. I'll post pics when I've finished it.
Old 7th Sep 2019, 11:45 am   #4
paulsherwin
Check the quiescent current using the service instructions. Quite a lot of these sets seem to have left the factory with the current set to 10% of the correct value, presumably because somebody on the assembly line had their meter set on the wrong range. A giveaway symptom is distortion at low volumes which reduces when you turn the volume up.
Old 7th Sep 2019, 12:05 pm   #5
tonygillett
Hmm, interesting. Thanks I'll check that out.
Old 14th Sep 2019, 8:08 am   #6
tonygillett
And it's done!
A very thorough clean, replaced all electrolytic capacitors and thanks for the tip re adjusting quiescent current. I checked it and sure enough it was way too low.
It's now a fine fine sounding and looking radio!
I replaced the lamp with an LED (adding a resistor) because I could only get a 12V lamp and when I tried fitting it it adversely affected sound quality.
Here are pictures of the finished article!
ID:	190135   Click image for larger version
ID:	190136   Click image for larger version
ID:	190137   Click image for larger version
