Old 27th Aug 2019, 12:41 pm   #1
boombox
Default Linksys/Sipura SPA3000
Hallo!
Trying to upgrade the firmware on a new Linksys/Sipura Spa3000 from what it's arrived with (3.1.10(GWd)) to 3.1.20(GW) which is what my existing SPA3K is on.
I can't remember if I had to manually upgrade my existing one or if it just happened to come with the later firmware.
Anyway I've SCOURED the internets and I cannot for the life of me find a working download link for 3.1.20.
Anyone have one saved locally?
thank you!
Forgot to say - the reason I'm upgrading is because I'm trying to restore a saved configuration and I'm getting the message:
There are errors in your inputs (fields with red names),
Please correct them and submit again!
only - there are no red field names. I've tried removing the passwords *** and even replacing the *** with '123' and the error doesn't go away.
I was thinking maybe the error is caused by incompatibilities between the different firmware versions?
boombox is offline
Old 27th Aug 2019, 4:23 pm   #2
Graham G3ZVT
Graham G3ZVT's Avatar
Default Re: Spa3000
Found it here:
https://community.cisco.com/t5/atas-...e/td-p/1336430
My 3000 came with 3.1.20(GW)
At your own risk of course.
Graham.
G3ZVT
Graham G3ZVT is offline
Old 28th Aug 2019, 2:50 pm   #3
boombox
Default Re: Spa3000
Thank you! That did the trick! I'd actually been on that page but missed the fact there was a file there to be had. D'oh.
And to cap it off, clicking that link and seeing the updater application reminded me I did do this about a year and a a bit ago, on that occasion finding the file myself... I must have deteriorated in the intervening time!
For future Googlers: I found the application updater didn't work, but I got it to work with the HTTP server url?file method.
boombox is offline
Old 28th Aug 2019, 6:27 pm   #4
Graham G3ZVT
Default Re: Linksys/Sipura SPA3000
The first time I did a firmware update on a Linksys ATA I had no application and I set up a TFTP server on my PC in order to flash it.
I knew you could save the configs as individual HTTP pages, and POST them back to a different unit, but I didn't know you could flash the firmware in a similar way.
Graham.
G3ZVT
Old 29th Aug 2019, 6:08 pm   #5
boombox
Another question if I may, Rambo & if you're still there?
I have configured a SPA3000 as a 'hotline' - when it goes off hook it rings '60' on my PBX - all of this works - calls can be answered and it's 90% working satisfactorily.
The only slightly disconcerting thing is that callers on the hotline (i.e. outside the building won't know the call is progressing because they're not fed a calling tone (what IS the correct work for that tone?!) - they just get nothing until the call is answered.
Anyone know how I would configure the Spa3K to dish out a 'calling tone' too?
This was all I changed to enable hotline functionality:
Code:
DialPlan: S0<:60>
boombox is offline
