Old 21st Aug 2019, 11:48 am   #1
ms660
ms660's Avatar
Default Circuit Analysis?
Out of interest, ideas on this one please....
EBF80's D2?
AM detector load path?
https://nvhrbiblio.nl/schema/Grundig_80U.pdf
Lawrence.
ms660 is offline
Old 21st Aug 2019, 12:59 pm   #2
kalee20
Default Re: Circuit Analysis?
I wondered if it was a clamp diode, in a delayed-AVC system. But I can't see a high-value resistor trying to take the AVC line positive (until overcome by a strong signal's negative rectified carrier). So abandoned this idea.
I think it's just there to give a bit of negative zero-signal bias to the AVC line by contact potential.
kalee20 is offline
Old 21st Aug 2019, 1:09 pm   #3
ms660
ms660's Avatar
Replies in bold bold:
Yes....me too
I think that could be it
What about the AM detectors diode load path, is it like that to save on switch contacts or is there something else going on...
Lawrence.
ms660 is offline
Old 22nd Aug 2019, 6:46 pm   #4
Nuvistor
Nuvistor's Avatar
Is the AM load through the ratio det circuit, it does seem it saves switch contacts?
Frank
Nuvistor is offline
Old 22nd Aug 2019, 7:05 pm   #5
ms660
ms660's Avatar
I'm not absolutely sure Frank, there's a debate about this on the GVR forum.
The only description of the other diode I can find so far in a similar AGC setup is in the Trader sheet for the KB GR15 where it appears to be a clamp diode to prevent the AGC line going +ve, as to whether that's its correct function is a case of who knows at the moment until I can find some other reference that fits the bill.
All theories welcome..
Lawrence.
ms660 is offline
