Old 8th Jul 2019, 5:06 am   #1
FStephenMasek
Default F. Stephen Masek's Bush SAC21 restoration
This is an interesting radio with an attractive cabinet design. I'm waiting for a shipment of new "rubber" tuning gang mount grommets, but have started the electronic restoration and polished the chassis yesterday.
https://i269.photobucket.com/albums/...C21asfound.jpg
https://i269.photobucket.com/albums/...%20started.jpg
FStephenMasek is offline
Old 13th Jul 2019, 7:06 pm   #2
FStephenMasek
Default Re: F. Stephen Masek's Bush SAC21 restoration
The soft "rubber" grommets from Renovated Radios have been installed, along with regular grommets on holes for wires (Ace Hardware in the USA is a good source)
https://i269.photobucket.com/albums/...20grommets.jpg
Old 14th Jul 2019, 9:18 am   #3
terrybull
I like your jig for mounting the chasis. Did you make it.
terrybull is offline
Old 17th Jul 2019, 6:03 pm   #4
FStephenMasek
Terry, I bought that jig and a larger version from Steve Strong. Please see
http://radiostands.com/
The antenna transformer had an open coil, L-1. Somebody had coated it with what appeared to be candle wax. I wondered why I found what seemed like wax spilled on a tube socket and another place in the chassis... The form containing L-1 and L-2 goes inside the form for L-3 and L-4. Whoever worked on it last also had lost one of the screw to mount the L-1 & L-2 form inside the L-3 & L-4 form. They also had the volume control mis-wired.
I found a coil in my parts collection, removed the wire, put it on the original form, and coated it with some of Rima's nail polish. I need to finish the radio and hope the valves are good to be able to test it. L-1 is untuned, so it should work.
https://i269.photobucket.com/albums/...as%20found.jpg
https://i269.photobucket.com/albums/...ransformer.jpg
Old 18th Jul 2019, 5:08 pm   #5
FStephenMasek
I have finished replacing the resistors and capacitors. All of the tubes/valves have good filaments, and the audio works with a CD player connected across the volume control. I suspect that the RF and IF adjustments are way off, so now need to work backwards from the audio output to check and adjust it.
Old 19th Jul 2019, 12:50 am   #6
FStephenMasek
She is working and sounding loud! The RF and IF adjustments were way off, and I found one intermittent connection at the band switch I'd failed to solder.... I still need to adjust / align it, replace the dial string, and replace the grille cloth. I'm delighted that the tubes/valves are all good enough for it to work well.
https://i269.photobucket.com/albums/...image001_3.jpg
https://i269.photobucket.com/albums/...image002_3.jpg
https://i269.photobucket.com/albums/...image003_1.jpg
Old 22nd Jul 2019, 12:57 pm   #7
MurphyNut
MurphyNut's Avatar
That's a very thorough restoration going on there and I'm enjoying seeing the progress.
I think these sets are very robust my SAC 31 (the same as your apart from the cabinet) is working extremely well despite decades unloved in someones loft.
Clive
MurphyNut is offline
Old 22nd Jul 2019, 5:52 pm   #8
FStephenMasek
Do you (or you-all) also enjoy thinking about who previously owned our radios, and what they heard on them (WWII, perhaps the moon landing,...).
Old 23rd Jul 2019, 10:50 am   #9
MurphyNut
MurphyNut's Avatar
Very much, I own many 1930's radios and families must have sat in front of them listening to Winston Churchill speeches during the war.
The thought of that really make them seem all the more fascinating!
Clive
Old 25th Jul 2019, 8:25 pm   #10
FStephenMasek
It is finished, although I would like to find a matching on-off & volume control knob.
https://i269.photobucket.com/albums/...image002_6.jpg
https://i269.photobucket.com/albums/...image001_6.jpg
Old 26th Jul 2019, 3:00 am   #11
MurphyNut
MurphyNut's Avatar
Very nice indeed, the speaker fabric suites the set very well.
Interesting how this Bush set found it's way the USA, I might be wrong but I doubt they were sold there new in 1935.
Clive
Old 26th Jul 2019, 6:39 am   #12
John M0GLN
John M0GLN's Avatar
Yes all the time, one of my favourites is a 1939 RCA Victor 45X11, an AA5 set which I listen to 2 or 3 times a week, I can't imagine that any of the US armed forces would have brought it across during WW11, more than likely came to one of the US bases here after 1945?
John M0GLN is offline
Old 26th Jul 2019, 3:25 pm   #13
FStephenMasek
It had a huge old plug with three round pins on the power cord when I bought it, a strong indication that it was imported to the USA, but never used before now. It may not have worked for quite a few decades.
That fabric was a fortunate find. It is sold by Kenney Richmond on E-Bay.
Old 26th Jul 2019, 3:35 pm   #14
paulsherwin
paulsherwin's Avatar
The plug was probably BS546, a 1934 British standard which was largely superseded by BS1363 from the 1950s onwards. It is rarely seen in Britain today apart from in lighting setups in theatres, but it remains a current standard in places like India and South Africa.
paulsherwin is online now
Old 26th Jul 2019, 4:37 pm   #15
AC/HL
AC/HL's Avatar
My Grandmother took an Ekco 405 line TV to South Africa when she emigrated. Completely useless, but she had free passage with unlimited luggage on an ocean liner. It happens!
AC/HL is offline
Old 26th Jul 2019, 4:58 pm   #16
FStephenMasek
I just retrieved the plug from the trash can in my workshop area. It is marked 15A!
Old 26th Jul 2019, 5:59 pm   #17
paulsherwin
Standard UK rating of the era. You'd expect a radio to be fitted with a 5A plug, but if the only socket available was 15A you'd need an adaptor to use it, so it would have been easier to fit a 15A plug.
One of the objectives of the BS1363 standard was to eliminate the plethora of 2A, 5A and 15A plugs and their associated adaptors, which in addition to being inconvenient encouraged unsafe practices.
There was actually an even larger 30A plug in BS546, but this was largely restricted to theatrical and industrial applications.
Old 27th Jul 2019, 5:41 am   #18
FStephenMasek
Any thoughts on where to find an on-off & volume knob for this radio? Do you know if the small knobs were used on other models?
Indeed, I'd read about those older plugs earlier today. Multiple sizes with adapters must have been, at the least, annoying. The current plug and socket system in British areas is theoretically safer, but are injuries and deaths significantly different than in other parts of Europe or the USA? I am also a member of the small special interest group on electrical matters within Mensa, and helped write the original ASTM E2019 standard for conducting Property Condition Assessments of commercial, industrial and multi-family properties.
Old 27th Jul 2019, 9:36 am   #19
paulsherwin
BS1363 does have many safety features, and the standard has been updated over time to improve it still further. The main drawback with it is that the plugs are physically large, though not as big as the 15A BS546 plug you've been looking at. I don't have any accident stats.
BS1363 was partly adopted to support ring circuit electrical installations in the massive postwar building boom. Ring circuits require a fused plug to be used safely. Almost all older buildings had been rewired with rings and BS1363 outlets by the 70s.
Old 27th Jul 2019, 3:10 pm   #20
Paul_RK
Paul_RK's Avatar
Looks as though the knobs are probably the same as were used on the SAC25 and SAC35, perhaps other Bush models too. I don't recall seeing them on sets from any other manufacturer.
Paul
Paul_RK is online now
