2nd Jan 2019, 7:24 pm | #1 |
What is this? looks RAF?
Had it years but no idea where it came from or what it is.
2nd Jan 2019, 7:38 pm | #2 |
Re: What is this? looks RAF?
VR65 is indeed RAF nomenclature.
2nd Jan 2019, 8:26 pm | #3 |
Interesting, I like a bit of mystery chassis but it won't stop me being wildly wrong sometimes.
The style of construction and mains transformer, rectifier, choke and smoothing capacitor (all supposition) at top right suggest a base-station unit, maybe rack use. Demodulator valve under the big bottom left can? Perhaps a pre-adjusted single-frequency monitor receiver feeding line distribution, or a variable capacitor under the chassis making it tuneable across, say, the LF beacon band? |
2nd Jan 2019, 8:37 pm | #4 |
Whilst VR65 is indeed AM/RAF nomenclature, the ZC numbers on the IF transformers(?) are Army numbers.
A picture underneath would be useful, please. Andy |
2nd Jan 2019, 9:08 pm | #5 |
It does look more ground-station than airborne. I'm guessing that it's some sort of receiver or IF-strip.
I'd think the can on the left is the front-end: the rusty protruding spindle with the screw-thread - could it be the spindle of a capacitor? I'd say the valve on the right with the brown Paxolin top-cap I'd guess is the detector or 1st-audio? VR65 is the same as SP61 which was a 6-volt variant of the 4-volt-heater SP41 originally designed in the late-1930s as a RF-amp for Band-I TRF TVs - it was used in a lot of WWII gear in roles similar to the EF50, and I gather it proved to be rather more-reliable in service than its better-known metal-cased companion. |
2nd Jan 2019, 9:21 pm | #6 |
Thank you all so far,I will get a picture of under chassis Thursday.
PS It is cold and dark out there tonight!
2nd Jan 2019, 9:23 pm | #7 |
It is possible that in it's present form it may have been modified for use as a sound channel in a home constructed television receiver.
VR [valve receiving] 65. As HE has mentioned, Mazda SP61. J. |
2nd Jan 2019, 9:23 pm | #8 |
Yes- perhaps that can could be the front-end of a relatively "local" performance receiver, there were things like SBA at ISTR around 30-40MHz or so. Were there such things as Gee monitor/check ground sets?
2nd Jan 2019, 10:26 pm | #9 |
Is that a part number on top of the 'mains' transformer? The picture is too low-resolution and fuzzy to make it out, blowing it up doesn't help.
Andy |
3rd Jan 2019, 12:12 am | #10 |
Well David, its nothing I recognise from my RAF Air Wireless/Air Comms days(1960's/70's). More than likely something from a ground installation. The valves are not secured enough for aircraft use, for a start.
Regards, David |
3rd Jan 2019, 9:35 am | #11 |
The varnished screw heads is an Army thing. The WS38 uses the same style of IF can, I've just checked mine but it has no numbers on it.
3rd Jan 2019, 1:49 pm | #12 | |
I certainly have some Air Ministry VR and VT valves that are actually labeled on the glass "for ground use only". |
3rd Jan 2019, 4:13 pm | #13 |
Enclosed photo,s.
3rd Jan 2019, 4:54 pm | #14 |
Again, an Army reference number on the transformer.
Andy |
3rd Jan 2019, 7:33 pm | #15 |
Interesting that it's got a Belling-Lee coax socket in one place and a couple of Pye coax-connectors elsewhere - this hints that it's been 'got-at' post-WWII.
I'm still wondering what's under the big can with the rusty screwdriver-slotted bit sticking out the side. |
3rd Jan 2019, 9:20 pm | #16 |
Mains transformer?
3rd Jan 2019, 10:36 pm | #17 |
3rd Jan 2019, 11:19 pm | #18 |
That can is marked "V6 VR65" so at least we know what valve is supposed to be in it.
3rd Jan 2019, 11:36 pm | #19 |
Maybe a test jig, with a fixed frequency amplifier strip into some measurement/indicator device? Even if that bit seems to be essentially complete, quite a bit else is missing!
4th Jan 2019, 1:00 am | #20 |
